Upping The Boost On R34 Gtt
Leeman
 Share
You can use a apexi boost control kit that goes with the powerfc. Or you can just run a seperate boost controll unit. The boost controll kit with the powerfc is a little extra but if you havnt bought a controller yet id go with that and get it at the same time you can buy it with the group buy aswell.
can i just get away with using my profec b controller and not the power fc? what are the main advantages for using pfc compared to not using it. im only putting boost up to 11 or 12psi?
advantages is you wont have the restrictions of the factory ecu and it can the powerfc tuned will make the most out of all the modifications giving the car not just more peak power but making the power throughout the rev range that much better aswell.
I would definately get a pfc before a boost controller, you will get better gains out of just a computer than just boost, as the R&R is so savage on these. Having said that save up and get both, for that sort of boost level, you dont need any fancy electronic boost controller, a bleeder will work almost as well, and save you some money on the dyno and fitting as well. If your hands on, you could build a Jaycar IEBC, which is probably one of the best boost controllers aound, and it s $140 with controller.
 Share
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
    • Found some from 2009. The lobster bends were smoothed out on the inside with minimal gaps (perhaps 2mm) where the silicone joiners were used.
    • And if you have to drive it in a civilised (or excessively woke) US state, find a way to register and insure it in a redneck state, so you can roll coal in it without worrying about legalities.
