Shell Optimax Replacement "v Power"
R34 VSPEC
 Share
Hey guys and gals,
Just got a tank full of Shell's V POWER and I don't know whether the cold night air is doing wonders or the new fuel is actually quite good. Apparently, this fuel was developed and used extensively in Europe on Ferraris and other exotics and is only recently appearing in petrol stations here in QLD at least....try it next time and tell us what you think.
Cheers
Kwei
from what i've read of their literature etc, it seems that it's basically just optimax and optimax extreme with 'friction modifiers' added.
the name V-Power is what it is called in Europe/most of the rest of the world, so i think they just re-named it to bring it in-line with the other countries, so now they only have to market one product instead of 2
I use to use Optimax, but since thats been replaced by V-Power I'm use that now, I've found a few diffrences with the engine running smoother etc, although I did a service on the car around the same time I started using V-Power.
Anyways, they say it's better then Optimax, almost the same just a few minior changes to the fuel.
R33MidnightRacer
Optimax = V-Power
When the name changed the product code for the fuel remained the same, it also uses the same tanks underground and they didnt clean them out or anything.
Thats because its the same fuel, just re-branded...
Optimax = V-Power
I was told by one of the people working at Shell, they have minior changes ? :)
i have used it, at the end of the day any fuel from a tank at your local servo isnt going to give u anymore power that another brand does.
if it had added octance booster or something then maybe but they willl never do that for the general public.
Ok just went and filled up on 3/4 tank of v-power...
$105.9 at Aspley Shell
Anyways i asked is it an optimax replacement... They said "YEs, and its better." I said "better how", the guy said "its just better" with a look on his face of this guy is a knob...
yeah exactly, they dont get taught why its better, they just get taught to tell ppl its newer so its better.
monkeys man monkeys!
i heard one guy trying to tell some rich lady in a merc that the opitmax was the best on the market
and she shouldnt use any other products and stuff from other companies... i just laughed bcoz she was hanging off his everyword.....
of course hes gonna say its the best bcoz he works for them derrr!
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
