Asking this on behalf of a friend and fellow user of another forum.
Recently completed RB20 Swap... just a straight swap as he blew his other one, DET Auto exactly the same engine as before and all runnign components just used a different block n head basically.
Car will crank over happily but will not fire, plenty of fuel, plenty of spark. List of things tried so far:
Replaced Ignitor
Replaced CAS
Replaced Injectors
Replaced & Checked Coils and Plugs
Replaced Loom & Injector Loom
Checked Compression
Replaced every fuse and every relay
ECU says Nil Errors (Code 55)
Replaced Inlet Manifold Gasket and Throttle Body
Checked Timing (spot on)
The thing has no intercooler pipes on it, meaning no AFM, so dont expect it to idle but it wont even fire or try to fire, just free spins. Plenty of fuel getting to the engine so its not the fuel pump either.
TPS or 02 Sensor? But I thought it would at least fire even if they were borked. Im stumped, advised him to go get a proper diag on it as im out of ideas but thought you guys may be able to point out something we have missed.
Cheers,
James.
https://www.sau.com.au/forums/topic/138714-rb20-wont-start/
It's got way too much air. It won't fire. The car also won't fire up as you're only running the TPS sensor and Map sensor. It'll be wanting the AFM meter as that is it's main information source.
Hook the pipes up, and then give it a kick in the guys!
https://www.sau.com.au/forums/topic/138714-rb20-wont-start/#findComment-2583856
If the AFM isn't connected then the car will start in limp home mode. It works completely fine til about 2500rpm, where it hits a rev limiter.
https://www.sau.com.au/forums/topic/138714-rb20-wont-start/#findComment-2594877
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
