I have r33 Gtst - just had work done including - hi-flow turbo, timing belt, fuel pump, apexi pfc have intercooler, exhaust 3" etc. On cold start up, sounds like top end noise like a woop woop woop woop woop in quick sequence - difficult to explain but i thought maybe it was the new timing belt? It goes away when the engine is warmed up, any ideas?
https://www.sau.com.au/forums/topic/138724-noise-at-top-end/
Yer but where exactly do you mean grab it Duncan? :P
Ive got new tensioner bearings (i run two on the 3Lt) and a new belt (although it is the rb30det belt) and it has a whoop whopp noise as well. Most nticable on cold starts, but there some other times as well.
Ive heard of a few rb25's that have the same thing, but the weird thing is nothing is wrong -they are all tensioned and setup properly, just noisy.
Edited by Bl4cK32
  • 3 weeks later...
Hey,
Got another one for yas! Got a noise in the exhaust. Had the whole exhaust system done about 4 months ago. It was done at formerly Hardcore Racing in moss street. about 2 weeks after the install I noticed this rattling noise. Checked it out and it sounded like it was coming from the mid pipe like some shards of turbo or something were blocked at the hi-flow cat. I disconnected the cat and found their to be no shards or anyhting forward of the cat. I then also noticed that one of the bolts where the turbo joins to the exhaust had been sheared off or was missing. Firstly, is it common for the RB25 to have this happen and second, could this possibly account for this rattling noise which like i said sounds like something like shards of metal flying around in the exhaust?
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
