  • Replies 55
ive seen r33's averaging around the 160psi mark.
Two r32's i had tested were around the 145psi~
Make it clear that deposit will be refunded if any (minor/major) mechanical/structural damage will be found. The mechanic should tell you condition of engine after compression AND leakdown test.
when looking for my R33 in australia (before i decided to import my own) i spoke to merli a lot on here...he gave me a lot of useful info on what to look for.
going by what he said, 120psi on all cylinders, thats rebuild time :(
he told me anything under 135-140 and you'd be lookin to rebuild soon after purchasing...
but everyones giving you all these facts, and you still seem to want it..so u want it that bad, get it
Ok heres the heads up. I put a deposit on the car last night so that they would hold it for me, I had to because the there were other people interested in it and 1 guy was willing to pay the full amount and get it as soon as possible. I believe him because on the weekend when I was looking at cars there was another guy looking at the car as much as I was.
I never delt with the salesman shane. Im dealing with a mechanic who does the compliance, mods etc... for Shane. People at my dads work have baught cars through this guy and they only had good things to say about him (mabey thats why my dad is so insistant on me going throught this guy)
The car is getting 120psi on all cylinders. Im still going to take it to someone else and get it checked out.
Good luck and hope it checks out OK.
You should have told us alot of people you know have dealt with him.
He needs to honor all his waranties or he will get alot of backlash ,.
funkymonkey the VIN number is 216083A
that dosen't seem right... the original VIN will be on a blue plate in the engine bay usually looks like "ECR33-123456".
Atreyu - tyre kickers come with the territory. It took me 10 months to sell my Lexus and I wasnt appealing to a younger generation dominated market. I carefully priced mine after the first month, 2nd from bottom of all ad's I could find. I still had people offering me 20K for a car that was up for 27/28K. Other Lexus' of a similar age and much higher km's were 30K plus.
It pisses us all off but as a buyer, people try their luck. Definately no need to get fired up though, you could quite legitimately have questioned the statement though as you wouldnt want it hampering any future sale. :thumbsup:
I know Saff Cossie. I think Im just over it. Cheers anyway.
DivHunter, no hard feelings. I know where your coming from.
Can you please delete what I posted and you copied in your reply?
Cheers!
brand new and from the manual the compression on a RB25DET is 1.2 MPa or roughly 175psi.
The variance limits between cyl is 0.1Mpa or ~14.5psi.
The service limit is 0.9MPA or 130psi
thats pretty much explains it all IMO.
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
