Free Old Air Conditioner
Oh yeah, always always always turn over an engine by hand first. -
So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
