Well, I was at sandown today giving the car its first track day with the 26. After one hard lap things looking bad. At full throttle above 6000 RPM the oil pressure would go from around 70 psi down to 50 and then start to fluctuate from 50 to 25 or so until I back off the gas and bring the revs back down to below 6 grand. Then after this happened twice I pulled into the pits and saw oil leaking from a cooler pipe. I removed the cooler pipe right infront of the plenum to find the plenum and cooler piping with a thick coating of oil in them. I am sure this oil is just blow by, as the engine has around 80,000 kms on it, but the swinging oil pressure has me baffled.
The engine itself is stock from an R32 GTR, with a High energy trap door baffeled sump, cam gears, power FC, rebuilt with steel wheel turbos, 3 inch exhaust and running around 15 psi it was making just under 270rwkw.
I now have the car home, it seems to be running fine but blowing a bit of white smoke, this could be from the oil in the cooler and piping tho. Oil is Mobil 1 5w50 and level is spot on.
What is your take on this, what can you see causing the oil pressure fluctuation?
I think a rebuild will need to be done, so now I need to work out what sort of rebuild do i want!
https://www.sau.com.au/forums/topic/138753-what-has-gone-wrong-with-my-rb26/
thats the problem!!
gtr sumps are crap. you need to overfill them by about 1.5-2L for the track to stop OIL SURGE.
thats the problem!!
It isn't a GTR sump, but a High Energy trap door sump.
I have been told i may need restricters in the oil gallery to stop the oil from gathering in the head?
could be rings or turbos, but if turbos were recently rebuilt, its prolly rings. do a compression test to see if you cracked a piston or something. it may still feel like its got all the power there and runs fine, but still have something really wrong with it.
all depends on how much oil your loosing into the pipes. also dont the older rb26 oil pumps tend to give up with lots of high rpm?
Edited by HRthirtyone
Yep, I just read the 5 page thread on oil control by Sydney Kid. It seems to make a lot of sence, I guess all the blow by could be caused by the oil pooling up in the head?
I guess the oil control mods outlined in that post should be done, it can only help.
Yea ash, I will speak to benno tomorrow and suss it out. What bothers me is until I noticed the gauge I was pushing up to 7,500 a fair bit, so I am thinking I should replace the main and big end bearings just to be sure. And if I am doing the bearings I probably should to an R33 crank or fit the oil pump drive collar and a better oil pump while I am at it.
And then while I am at it I may as well re ring it or fit forgies, and the turbos will be off.....so a set of GTrs? turbs may find their way on too.......
Now do you see my problem? I have an ilness.....I am a modificationaholic.....I need help......
But my wife is encouraging a build.......so this is looking to be messy.....
Have you changed the oil pump?
Did you install the cooler?
Do you have a catch-can?
I had my front main seals changed 3 times before I gave the mechanic a N1 oil pump.
I was also having oil pressure problems.
Luckily for me I had acted at the right time, the screws were nearly about to fall off.
Sometimes too there could be a blockage in the line, rare as it seems, some have been unlucky.
Get everything checked out before you go out again. or you may have to build quicker than you thought...
Hope I have been of some help.
Cheers :P
John - i know your issue, i have the same illness :P
Just remember, once its apart, it never ends cheap and it will cost you 5 figures end to end.
IMO - if the motor isnt dead and you check it out and its ok, dont touch it.
You have the steel wheels in there so you dont have the danger of it letting go. Just wait till it dies then pour the cashola into it.
Motors take a matter of weeks to be done, so its not like when it does die.. you'll be without a car forever
I hear where you are comming from man.
I am just worried I may have done some damage to the bearings with the oil pressure dropping at the revs I was pulling.
What engine is yours? Or more importantly, what crank and oil pump you using?
In the back of my mind there is the fact that mine is an R32 engine, and they are known for dodgy oil pumps.
I just want to make it reliable....
Hello again,
All RB motors have a potentially dodgy oil pump, RB26 out of a 32 has a greater chance due to its age.
If you want to do track work safely ,get a larger sump and as Ash has stated, get some restrictors to stop the top from getting to much oil.
As you are getting a larger sump get the oil and water pumps. Jun oil pump with collar if you are really serious. Also get the Bearings ,Bolts and timing belt changed .
Then you might have a reliable car :laugh:
There are too many things that can go wrong with the RB26 motor....if not looked after properly.
The supporting mods. are endless but the Mod itself must be maintained for it to work.
Anyway like you and Ash, I too am a modoholic (?) .
Thus, I am on SAU to navigate my next steps. :)
Cheers and good luck :)
You know what mine was, i did buy it off your cousin :wave:
Was a 32 motor, but obviously did the collar and what not as part rebuilt, and an N1 oil pump. Virtually the same as my 25 rebuild but in the 26!
Is there a was to check if you have done any damage? Ive got no idea on that one... if there is then that could save you some heartache.
An oil pressure guage can give you a little indication of bearing wear.
Also you could look into an oil evaluation which can also give you a fairly accurate indication of bearing condition etc.
By far the best way is to pysically hold them in your hand and inspect them though.
Personally if its not rattling and carrying on id keep using it till she displays symptoms of bearing wear etc.
HAHA.......
After havin a chat with benno I am going to rebuild it regardless, as far as I know from what the inporter told me, it has 80,000 kms on it.....although....he also told me it was an R33 engine.....which it is not!
So yea....it is running fine now but it has got a fair bit of blow by, so might as well get it all sotred in one hit.
You know what mine was, i did buy it off your cousin :)
Remove the oil filter and peel it open with a stong can opener and see if there is any copper coloured material within the filters.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
