the latest turbosmart FCD is a much better unit. it doesn't just clamp the signal. it clamps it at a set voltage, but allows you to keep the signal rising. you just bend the afm signal until it no longer hits r&r.
this will allow you to gain power even if you haven't hit r&r because it is leaning out the mixture. it works off a system just like a safc.
yeah as mad and the others have said just get an safc of similar device
make some more power in the rev range and avoid r&r at the same time.
magazines often leave out important facts or put down big power gains to little $5 devices, and not revealing the true gain of power.
OK so humor me then. When i did the tune on my computer, we actually had to add fuel at 4500 rpm, so now it hits boost cut, if i get rid of fuel through 4500 rpm with my safc II, it will remove the cut as the ecu thinks less air, correct. Dam it, if so i'm going to ritchen the map by increasing the fuel pressure and then back everything off in the SAFC II to get rid of R&R. Correct.
Edited by WogsRus
