What is it with Holden drivers?
I'm not someone who has the ability to cut back on my attitude, if someone f**ks with me. If no one f**ks with me, there will always be a complete lack of attitude, coming from me. I found this website after searching for the under cover I mentioned above. I had no idea that SAU.com.au was Skylines Australia. For all I knew, it meant Subaru Autos United or some shit! I got an attitude from the first person to comment. And Aussies aren't the only ones allowed to have attitudes btw. I was born and raised on the South side of Chicago, where attitudes were invented. Don't believe me? Then you should visit the South side some time and find out. Fyi, I wouldn't venture too far outside your motel at night. Probably not a good idea to go anywhere in the morning or afternoon either. And never answer the door, or look out the window. Wedge a table or dresser against the door and leave it there at all times. Also, put 2 wet towels against the bottom of the door, and keep the lights off at night. Other than all that, you should be fine. If you make it out to your rental car. Cheers!
By PotatoCake · Posted
Thanks for that, sounds like its definitely worth getting as part of a freshen up -
And no, this was not posted on April fools. https://www.theautopian.com/bmw-wants-you-to-drive-with-an-air-compressor-attached-to-your-wheel/ What happens when it's not attached properly and flies off into somebody's head?
