I was thinking bout bending up and making dual exhaust tips, and glassing a second exhaust pod into my rear bar.
What do you guys think?
Im waiting for my adjustable gtr wing to arrive to fit to the cf boot.
Edited by Silent
https://www.sau.com.au/forums/topic/138813-dual-exhaust-tips/
hey mate
personally im not a fan, i like the skylines with one exhaust, if you have 2 man its gunna resonate heaps 2.
but its all up to you mate, if it was me i would be thinkin of a duel twin out the original cut, like drop off the cannon and get a nice duel tip, i have seen em str8 through on another 33, it was a gtr tho and had a seperate exhaust for both turbos.
ive got a dual n1. they are the dogs nuts. wouldnt swap em for anything. good luck in finding one though as theyre not made anymore and hard to come by. theres also a trust version out there too
took me all of 3 minutes to find :spank:
Apexi Dual n1
looks good
The main problem I'm expecting is with the position of the fuel tank on the right hand side. I'm also going to need to modify the rear bar to make it symetrical, which is going to be interesting since I've never tried to fibreglass before. I'm keen to make it work though so hopefully it'll be done soon.
Is your rear bar standard? If it is, all you have to do is cut the exhaust hole.
I have done quite a few of these, as long as you take your time they look good.
I'll have to find a pic of an xr8 i did last week.
I've just organised a Veilside rear bar which I'll hopefully pick up tommorow. I won't know exactly where I stand until I see it on the car, but I'll have to make it look the same on both sides, while keeping the mufflers as high as I can without seeing the fuel tank etc through the cut in the right side. Shouldn't be too much of an issue, best scenario I just cut out part of the right side, worst case I'll have to cut part of the right, and fill up part of the hole on the left. Once that's sorted and painted it's off to the exhaust shop.
Silent I don't suppose you've fitted a veilside rear bar before? Do you know if they sit much lower then the standard bar? If the do it'll make the whole thing a lot easier.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
