  • 2 months later...
I finally got my twin exhaust! It took a lot longer then expected, a bit of mucking around and cost a fair bit more then a conventional exhaust, but I'm very happy with the result!
Credit for the exhaust work goes to Mercury Motorsport. The end result was even better then I'd hoped for!
I'll get better\more photos once I clean the car.
whats the sound like? louder?
I had the stock system before so it's obviously louder then that, but overall it's not too loud. Definately not quiet but not as loud as many other systems. The best thing is there's next to no drone, and at higher revs it sounds great.
Im considering losing the cannon tip for 2x twin tips exhausts.
I have DTM tips on my 8
http://i70.photobucket.com/albums/i88/miss...ts/DSC02093.jpg
am sure you could find something better suitin your skyline tho... hehe think they come in straight rolled edges also
or borla angled tips look nice..
http://www.autoanything.com/exhausts-muffl...5A2421A0A0.aspx
maybe just go into exhaust shop and see what they have :no:
Edited by MissyK
very nice and neat setup! I'm wondering though if there is any loss in power with this kind of setup? Noise levels would probably be over the legal DB limit too?
When I get around to putting the car on the dyno I'll see exactly what the power gain has been, but I don't think it'll be any different to a normal 3" system. The twin 2.5" pipes have a greater cross section then a 3" pipe, and the bends are nice and smooth so there should be very little restriction.
Not sure what the dB reading would be, but hopefully it won't attract too much attention.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
