Its been a bit hot lately and I've noticed my Oil temperature gauge is reading slightly higher then the normal 90c mark, its been very close to 100c if not at 100c these past couple days. Just wondering if this is ok for the GTT Skyline? Should I perhaps do a coolant flush and replace the coolant?
https://www.sau.com.au/forums/topic/138834-oil-temps-close-to-100c-this-ok/
Don't worry about it. The stock water temp gauge shows nothing. I boiled over and it didn't even make it to the hot section.
My water temp on the track the other day was 109 and it didn't move from the middle.
100 for oil is fine. If it goes over that much then worry.
My car runs about 95 in normal street conditions on hot days.
The other night (cool night) I took my car through the hills, giving it pretty hard for about 10minutes flat out, and the oil temp reached about 105 degrees.
I then drove it normally for 10mins and it stabilised back down to 95.
Is this okay?
I am running Motul 8100.
>120C and I'd be thinking about easing up because the oil viscosity will be thinning out. But if you are using the 5W50 then it should still be OK but still wouldn't venture over 130C under any circumstance.
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
