Engine In, Engine Out... That's What It's All About!
  • Replies 54
Guys that is a monster performance i have to say.
So slide i see you like to work for steaks? You and i are going to have to become friends cause when the GTR comes along i can see some work coming with it.......Mod work of course!
Now now, don't you go using and abusing my slidez0r... i'll f*k you up good and proper if you do :(
Now It just needs the monster turbo to go with it!
After hearing Jarrads car I want external gate lol
*slaps forehead* oh dear :O
what are you talking about its quite as :P
baaaahahah ah ha ha ha
Actually the fuel pump is WAY louder than anything else :):D
Well my engine has gone.. very sad moment actually crashing the car 5 weeks afta it spends 7 months in a shop is a sad moment.. I am suprised we got it done just ask slide normially working at my house takes longer then it should with everything on cars.. Ohh and u owe me a ride now in that 32.. Go the paint job i must have known when i painted it it was going to go in your car good colour match lol..
Enjoy the engine...
I know how crazy is the colour match! It was just meant to be! Thanks for everything mate ;)
Now now, don't you go using and abusing my slidez0r... i'll f*k you up good and proper if you do :)
Me use and abuse???? :D I would never do that to a fellow skyline enthuseist (spelling??)
sorry aaron, but we rnt gay like those southerners :)
Yeah the NSW family is alot stronger and larger then Qld
I will allow you to buy parts from me aswell :)
Enjoy the engine...
Nobody likes fags that ride bikes :)
what are you talking about its quite as :D
Its only loud because the gate opens 5000rpm before it should.
And stop thrashing it when you just turn the car on lol it makes me cringe :O lol
And stop thrashing it when you just turn the car on lol it makes me cringe :dry: lol
I cant thrash it because I can go above 5500 rpm because the coil packs are stuffed
Enjoy the engine...
Ok you can have a ride after it is tuned (Afterall the tuner is just around the corner from your place!) And yes the colour does match rather nicely! Good choice;)
hahaha whats wrong with bikes.. Bikes are wikid esp when u have to drive to a certain slides house all the time and he lives in tweed so i have to deal with all the traffic bikes are better straight up the outside YES no traffic.. So move closer and i prob sell my bike hahaha.. Ohh i got my new go kart today i will drive that to your house instead then jsut go under cars instead of around...
stop typing like your on a mobile noob and stop bitching :mad:
you love me :mellow:
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
