how r ya guys, im selling my beloved gtr. colour is gun metal grey and the car has done 135,000 genuine k's. car has been regularly serviced, every 5,000k's sometimes earlier than the service time as well. car has full major serivce when it landed in melbourne, the car had been worked on by a work shop called hokue racing factory in japan and the bottom end has some aftermarket internals which im not sure of, but all the work in melbourne has been done by benny kashima from hi torque performence in dandenong. the reason im selling is due to a purchase of a new house, so some extra cahs flow would be great.
anyway here are alist of the mods on the car that i have done and some came with the car.
33 N1 engine
jun cam gears
hks cam shafts
jun valve springs
garett 25/60r turbo's
apexi power fc
greddy profec b boost controller with hi and low boost settings.
turbo timer.
half cage cage in the car, blck colour.
rebuilt 33 gtr gear box.
hks tripple plate clutch.
short shifter.
apxi air pods
hks intercooler.
trust boost and oiul pressure gauge
fujitsibo exhaust, quiter than stock.
sard 660cc injectors.
bosch 040 in tank ful pump
apexi n1 coilovers
trust brake pads.
slotted rear rotors and cross drilled front rotors
Apexi sway bars and strut brace
aero vented bonett with bonett pins
hks kansai front lip.
$2,000 stereo alpine sound system which is still in the box, i hav not yet fitted.
rims, not sure which ones.
ATS two way lsd front and rear.
on hi boost 18psi the car produces 335rwkw and still has more in it. i have all the dyno sheets and reciepts of work on car as well. my lo boost setting 14 psi for the street and prodcues 282rwkw. the cams are yet to be dialled in so the car can make w hole lot more power as well. perfect for circuit racing and drag racing, car is very responsive, bosst comes on at 1,800rpm. car ran a flat 12 sec at 115mph on my old standard set up, with standard turbos, no injecotrs and no pwer fc, so the car is ready to run deep into the 11's.
PRICE is $34,950. only serious buyers please. contact me, bobby on 0419 326 708.
will post up pics soon.
Edited by Bobbygill
https://www.sau.com.au/forums/topic/138893-modded-32gtr-for-sale-melbourne/
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
