hey guys... im relatively new to the skylines scene around here
ive got a rb20det with a r33 turbo in it... i was just wondering what exactly the r33 turbo is... stats/ figures... brand etc....
ive tried searching thru the forums and found nothing... maybe im just an idiot but yer... just a general qs...
thx... would be a good help...
https://www.sau.com.au/forums/topic/138919-r33-standard-turbo/
its not a garret? i thought it was...
its compressor wheel is steel, while its exhaust wheel is ceramic, just like the rb20 turbo. this means that at high boost it can generate too much exhaust heat and the exhaust wheels can delaminate and separate from the shaft. That's why people say generally they have a maximum boost that should be run through them without damaging the turbo...
on an rb25 engine, its good for 11-12psi max
on an rb20 engine, its good for 14-15psi max
its a great little upgrade on the rb20 motor as it provides more high rpm pull without getting too much lag down low
PS welcome to SAU :rolleyes:
thanx guys... clears out what i wanted to know... atleast its better than the stock rb20det turbos... mines running stock boost atm but i got 3 stage evc set to 8/10/12or14(not sure) and everything is fine when i drive it... only problem is a bit laggy... kicks in at about 3500 rpm or so... but fun cause its so loud!!
eh ur turbo kicks in at 3500rpm? my HKS GT2840 is boosting from about 2000rpm why so high?
because if you read the first post yo would see he has the rb25 turbo on a rb20. rb20's don't spool as early as 25's.
and yes they are really ball bearing. it is slide's highflowed ones that aren't. the only difference is the spool up time. once they are up and going they perform just like a ball bearing.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
