If its in a turbo engine light weight flywheels are a disadvantage. A more weighted flywheel helps momentum between gear changes. Keeps the revs up for better turbo response during shifts. Or so i've been told. Just machine your current one to remove the risk of shudder.
My experiences
Stock flywheel = Easier to launch at lights.
Lightened flywheel (4.8kg) = Little harder to launch at lights, but much nicer to drive everwhere else. Car revs through the range faster, and responds faster on downshifts etc.
Hard to explain, but the car just feels more 'happy'.
As I said, just my experiences.
-Insu
If its a ceramic clutch they rip the absolute crap out of the stock flywheels. Big grooves. :S
In a nutshell it needed a few more rpm to launch without bogging BUT it was easier to control wheel spin when launching. High rpm gearchanges are noticably quicker, the next gear simply drops in.
Once moving the lighter flywheel made the car feel as if it would accelerate easier/quicker in first. It felt brisker and more willing.
In the higher gears there was no noticable difference to acceleration.. Only in first allthough I swear it made the car feel as if boost snapped on harder in second.
Overall.. On an RB20 that needs all the low speed acceleration it can get its a worth while mod with real benifits that I would do again.
Do remember not to go too light as the flywheel weight isn't as important as where the weight is removed from.
A 5.5kg flywheel that has a heap of material removed from the outer will offer less resistence to spin up than a 4.5kg flywheel that has less material removed from the outer but more from the inner.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
