Hi Guys, well this is my car.
I am thinking about either painting my rims white, black, gunmetal or bronze OR putting them on the family magna wagon and getting myself some new rims...
I am interested in seeing what others have on their 32's and how big you can go. CAN I FIT 20's under there??
My current rims are 18x8's (not sure of the offset but I believe correct - maybe 35) and I have had to trim the rear guards right back to 'minimise' scrubbing. Can I get a wider tyre on if I get a different offset (taking them in further) or will that just cause more problems?
Anyway, this is as much for me as for every other R32/Skyline lover out there... Post your pics up and give your opinions!
Thanks guys!!
Todd
https://www.sau.com.au/forums/topic/138932-r32-wheels/
get rid of em mate, put them on ya commodore. lmfao.
20s...umm possible, but mods to ya guards for sure, and must get low profile tyres, probably something like 205x30xR20 for front, and 215x30xr20 for the rear.
i hate to see holden wheels on jap cars, or japwheels on aussie cars, just doesnt go together.
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2587613
ratedGTR - they arent holden wheels, they are just an after market wheel mainly produced by BSA. also 30 series rubber for 20s is rare and only comes in 225 and wider.
CATKICKER - ive got 20x8 on my car and they only scrub a tiny bit when i go over big dips in the road at decent speeds, but ive got GTR front and rear guards. you could probably fit em with the right offset, camber, tyre size and height.
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2588058
Cool... well since mine are 18x8's and rarely scrub, if I were to fit some 20x8's with a 30 profile tyre, it should technically be the same width and rolling diameter.
I honestly have not seen 20x8 before, only 20x9's. what are yours? can you post up a pic? I can't see to well in your sig...
raterGTR, post up a pic of your car/wheels.
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2588179
no it wont be the same rolling diameter
you can fit 22s if u wanna keep the car sitting like land cruiser
but the problems start when u lower the car
because the wheels will need to sit inside the guards for it to look any good
my wheels are original AME modelarts, they are a light weight 3 peice jap rim.
cant buy em anymore cause they stopped making em years ago
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2588236
see now that is tough!
how does it handle with 20's? Mine sits about the same height (just slightly heigher, which is fine for me and my daily driving)
i am just not sure if it is worth the trouble getting 20's just to say i have 20's... maybe it is but 19's would still look big! It's not like the 18's look small (well the do compared to yours :D )
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2588278
18's look small compared to that for sure, but there are still some nice 18's out there, and the cost for them (and tyres) wont be as bad
Ive always though black powdercoated rims like your current ones wouldnt look to bad on a silver R32 :laugh:
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2590375
handles like shit with 20s lol
nah its not too bad obviously it would be better with smaller rims.
i want to go lower because there is still a shit load of ground clearance
having the car sitting the way mine sits now wont happen on a GTSt
unless you get 20 x 7.5 or something really thin
and have heaps of negative camber
https://www.sau.com.au/forums/topic/138932-r32-wheels/#findComment-2590982
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
