Hi guys no time no see, how are you all? [:)]
Got a question on a R34 gearbox, i wonder could RB25DE gearbox able to fit on a GTT?
Because what i heard GTT is using a pull type clutch (correct me if i'm wrong), but RB25DE is using a push type clutch as well as using 6 bolt flywheel.............so if i'm thinking of a manual conversion....will that be all right?
Thanks
steve
https://www.sau.com.au/forums/topic/138953-r34-gearbox/
Hi guys no time no see, how are you all? [:(]
Thanks
steve
Any bro's knows about that? cheers
https://www.sau.com.au/forums/topic/138953-r34-gearbox/#findComment-2589125
34 is a pull type gearbox so when you put 33 in it will be push. its just the gearbox..so if you use 33 box,you get all 33 parts needed. ie. clutch kit, slave
What about the R34 R25DE gearbox? Will it be fit on a GTT? Need you guys the advise in urgent as i saw a R34 RB25DE gearbox on net, need to make decision b4 the auction closed
cheers
steve
https://www.sau.com.au/forums/topic/138953-r34-gearbox/#findComment-2593805
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
