Hey guys,
Love the car, absolute blast to drive, however now that i've been driving it for a bit, i'm starting to look into its hopefully minor issues.
Issue 1) After full wheel alignment and balance, car still has slight vibration at high speeds - i'm calling shit tyres since the guy at the workshop said the rear's where out of whack and slightly egged just want confirmation.
Issue 2) Car pulls to the left if I let the steering wheel go - car has coilovers but are old and way to hard and i think oversprung, possibilites? castor rods? control arm or something i can adjust?
issue 3) how to tell if car is over sprung - i think it is, had 2 people get in on the passenger side, was sagged and i could 'feel' the damper move and actually work rather than the spring just bounce around like usual - my thinking is with more weight its stopped the spring from moving as much and allowing the damper to do its job. With just me in the car, if i go over a large bump you can hear the springs 'resonate' and clang around.
Issue 1 and 3 i think can be fixed with new tires and a change in suspension, issue 2 i'm not sure about. No obvious viscous fluids so i'm not sure about the castor rods, but my mechanic is away so i can't talk it through with him.
Cheers guys! For once i'm actually looking forward to working on a car!
https://www.sau.com.au/forums/topic/138960-couple-of-handling-questions/
1. is the vibration through the steering wheel or through the seat?
if its through the seat, more than likely its the rear tyres fault as the guy said
2. cars pull with uneven camber and/or castor. they pull to the side with less camber/castor.
to fix the problem get castor rods/bushes. if the camber is uneven too get camber bushes/arms.
all this information will be on you wheel alignment report. both camber and castor should be very close to even.
if there is castor adjustment, wheel aligners will set the left up with 0.5-1.0deg more castor to accomodate for the natural camber of roads (which allow for water drainage)
Edited by salad
well there's my answer for the pulling to the left, wheel alignment report shows left at +4.41 degrees and right at +5.57 degrees.
Are the castor rods seperate to the bushes or are they together? Just replace both?
Vibration is the last thing ot worry about i guess, it only happs at about 110km/h plus. Before the alignment it was about 80km/h plus
sounds like front tyres still out of balance... alignment wont affect vibration.
rods are seperate to bushes. replace the bushes in the stock rods or replace the whole rod with an aftermarket rosejointed item
bush's are the more street friendly option.
i think you can get enough adjustment out, but im not sure, someone else will have to clarify as i've never had bushes.
rose jointed rods have a lot of adjustment, more than enough, but they're not recommended for street.
rose joints are illegal on the street, because when they wear out they fall apart.. Having your suspension detach in the middle is generally not a good thing :laugh:
You don't need that much adjustment on the street. On the track, sure.. especially with semis :)
If your alignment is fine but the bushes are clapped out just get the bushes replaced. Otherwise get adjustable castor rods and have at it (have seen the noltec ones for a 32 GTR and they make a brick shithouse look like a tent).
Vibration is either caused by out of balance, cheap out-of-round tyres or that your wheels aren't perfectly true on the hubs (you will probably get brake vibration if this is the case because the rotor will be out as well). Edit - if your wheel bearings are on the way out that can cause it too.
If the springs are bouncing around like you say it sounds like the car is oversprung. Personally I think it's foolish to run rock hard suspension on aussie roads, get some nicely matched springs and shocks instead!!
Edited by Kinks
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
