In preparation for Small Car Sunday a group of us taking part are hoping to get some vinyl cut stickers made up in time for the event & we also wish to make the stickers available for all SA forum members who are interested. Thanks to Howie & cookiebear's efforts for coming up with some designs.
These are the designs that you voted for & are now available:
SAU Logo Sticker
Description: 12cm (length) x 9cm (height)
Notes: Option of white & red (top pic) or metallic silver & red (bottom pic)
Price: (white & red) $3.30
(metallic silver & red) $3.30
Postage: +$1
Small URL Sticker
Description: 35cm (L) x 1.8cm (H)
Price: $3.30
Large URL Sticker
Description: 65cm (L) x 3.5cm (H)
Price: $4.40
Ordering: Please PM what sticker designs you would like & qty. ATM postage is only provided for the SAU logo & small URL stickers. Alternatively stickers can be picked-up or whenever I'm attending a SAU SA event.
https://www.sau.com.au/forums/topic/138964-sau-sa-stickers/
  • Replies 149
Posted Images
i'll go option 3... i could always cut off the sau part and use it somewhere else if need be.
For sizes... 20" wide for the front windscreen, 8" wide if it's for the side window.
Edited by Howie
https://www.sau.com.au/forums/topic/138964-sau-sa-stickers/#findComment-2588295
From my understanding, they'll be vinyl cut - that is, with no background. The black you see there is for illustration purposes only. Please correct me if i'm wrong Patrick.
yeah that would probably make sense! thanks for clearing that up
https://www.sau.com.au/forums/topic/138964-sau-sa-stickers/#findComment-2590371
No. 3 - and I would prefer it to be max 65cm long x 4-5cm high so I can put it sideways up the edge of the front windscreen ..... and I would like an SAU logo one to go above my GT badge on the front guards - it would need to be around 9cm x 9cm max. Thanks for the effort Patrick!
https://www.sau.com.au/forums/topic/138964-sau-sa-stickers/#findComment-2590787
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
