Hi guys! Just bought an intercooler from Justjap and will be putting on this week end. Just wondering if I need to trim the front Reinforcement bar? I need to know so that I can arrange an angle grinder to do the job. Any help will be appriciated. Cheers!
https://www.sau.com.au/forums/topic/138970-installation-of-justjap-intercooler/
Just have a look at the new intercooler and it does not have a nipple that pick up the hose to the actuator. Where do you guys tap the hose that goes to the actuator?
Best to drill and tap into the new cooler piping. Just pick the closest point on the cooler pipe.
I installed my cooler myself a couple months back. It was a nightmare. But it was my first time. And having all the tools you need at hand would make things a lot simpler.
To drill the hole under the washer bottle you need a good quality hole saw. Ibought a cheap one and it just went blunt. It's tough metal. I ended up using the grinder to cut a square.
  • 3 weeks later...
Well its been two weeks now and finally got my intercooler installed. The only problem I have got is that the fornt fog light does not fit. I have to take it out. Dont understand it as I have mounted as far in (close to the AC fan) as possible but still my fog light does not fit. Any clues?
I had to get rid of the fog lights too, just no room for them.
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
