gday guys
waiting for my mate to drop my digital camera back
in meantime, ive gotten a q45 t/b by mail
when the butterfly is fully closed, should it be perpendicular (90degrees) with the tunnel inside the t/b, or on an angle??
i know that may sound hard to get your head around.
the one i have, the butterflky when fully shut is on an angle. i want to know if this is correct or not
cheers, mark
https://www.sau.com.au/forums/topic/138994-q45-throttlebody/
How much of an angle? It should seal, the butterfly is not actually round, it is a very slight oval with machined edges at a slight angle so that when it is closed, it does not stick and can open easily.
Also some of them have some type of weired wax pellet idel control i think, well mine had something weired on it for idel control, so that could be holding it open if it isnt fully closed.
Edited by GTR1993
it is definitely sealing 100%
f**k it, ill justwait to get photos and post up
"the butterfly is not actually round, it is a very slight oval with machined edges at a slight angle so that when it is closed, it does not stick and can open easily."
after reading that, definitely makes sense that it looks the way it does
im worrying about nothing
  • 3 weeks later...
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
