Will post it tommorrow for you.
Its very basic.
You just need to put the car up on stands at the front, crawl under and find the filler plug first, its on the drivers side side of the gearbox and needs a 1/2 inch socket driver.
loosen off the filler plug (must do first, as if you can't get this off, you can't get oil in.)
get a pan and now undo the drain plug, this plug has a magnet attached to it to attract all loose metal fillings. let the oil drain.
i waited 30 mins and then started the refill process, just clean the drain plug, replace and start filling oil, you know the box has enough oil when it start to exit via the filler hole, I topped it off 3 times to make sure it was exiting oil and not excess on the pump i used to get the oil in the box.
Once your sure its full, replace the filler plug...done.
https://www.sau.com.au/forums/topic/13901-oil-changes/#findComment-284425
The photos..
ummm, errrr...I think I kind of deleted them...(spewing massive!)
I'm going to take the photos again of the locatios of the plug...I can replcate everything bar the photo of the drain plug.
Again....SPEWING!
https://www.sau.com.au/forums/topic/13901-oil-changes/#findComment-286198
