Hi All.
Well recently i fitted and adjustable FPR and it was fine for a while now about 2 weeks, but lately i can hear that in the morning, my pump, first pumps air, as you can hear no load on the pump, and then it fills all the lines and is fine. You can definatly hear that for the first 3 seconds it's not doing any work.
Now i have a new fuel pump Walbro GSS 342 with the anti drain valve, so it should be already pre prined in the system. I don't seam to have any leaks that i can detect as such, all seams preatty good, can't smell fuel anywhere, or anything funny, i checked all the hoses and filter fittings ect, no leaks.
So does this mean my antidrain valve has gone cactus, or there is a leak somewhere letting air in and hence allowing the fuel to flow back???
Can it be a faulty FPR???
https://www.sau.com.au/forums/topic/139015-fuel-line-priming/
dude..
you either bought the biggest dud car, or you make mountains out of mole hills.
What on earth would make you say that. Not my fault i am anal about everything, well ok it is, that's the engineer side comming out. The car is fine. ONE is allowed to ask a question.
I need to ask as i don't know if it could be a problem.
SO once again why do you think i broght a dud car?????
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
