I dont think so tim, the 4wd system used on the stagea is the same as 33/34 gtrs, meaning there is no "safe" quick switch from 4wd to 2wd, as the clutch packs still have hydraulic pressure in them and you run the risk of burning them out if you do not bleed the pressure out.
Please somebody correct me if I am wrong.............?
There is a "s" button, to the left of the steering column, it locks the power 50/50 front/back.
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2588841
Unsync'd. Most definately. Unless you are somehow managing to break traction with your launches. Ive used 50/50 for driving in snow and on dirt, but for launching, set all the power to the back, cos your car will rock back on its haunches anyway. Plus, if it needs to, itll feed more power to the front anyway.
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2590273
i got wheelspin from the front wheels in the wet with a hard launch.
I think i really got stagea launches down to an art, but yeh its simple once you get it.
I personally found no difference between S/No-S and 1/2/D or snow/power
Just No-S, D and normal got the best launches for me.
cant wait to drive my best mates RS4S and launch the f**k out of that and see how it spins.
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2590482
You'll find that if you have it set to normal, and put your foot flat to the floor, the power button will light up anyway. It just drops back gears more readily than normal, for if you are chuggin up hills or towing a trailer. Saves the engine labouring.
I think snow does exactly the opposite, stops it from dropping back gears, so the car is more controllable, and less prone to slippage. Foesnt change anything enginewise, i dont think. Just transmission settings.
I think. Thats just from me driving it around and checkin it out.
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2590991
Incidentally, the s2 stagea has no power button. I believe it does still have 'power mode' but just no button to activate it. It seems to automatically engage power mode depending on your driving style or if you put your foot to the floor.
In my last car (turbo silvia, auto) I used to leave power mode on all the time as I found it was more responsive with gearchanges and generally felt more lively. At first I thought it was a disadvantage for the stagea not to have a power button, but with the MV automatics shift kit (valve body upgrade) installed it does such a great job with the gears I really cant find any fault with it. Its a fantastic gearbox. :w00t:
I've heard snow mode just stops it going into first gear - so you just start off in 2nd?? Not sure if this is true.
And for the record, the 50-50 torque-split button (with the 'S') will hold 50-50 torque front and rear but only up to around 2500rpm or something and after that it will still allow more torque to the rear where necessary. :w00t:
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2591137
i thought with tiptronics pushing the shifter across to pseudo manual mode activates power mode if you dont shift manually
i only this as thats how the tiptronic in my territory works to activate power mode you push the shifter to manual mode but still let the car shift automatically
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2591268
It doesnt matter if I use the S button or not, high rpm launches just spin right through first, so I have found that anything close to about 5k rpm is the limit, anything over 5k rpm just spins all 4 through first, which is bad because all that happens is that the car lurches which ever way the road is angled, and because most roads are agnled towards the gutter.............
I find it spins easier with the S button on actually, definatly easier to do 4wd doughnuts, all done at a proper motorsport facility of course.
https://www.sau.com.au/forums/topic/139016-2wd4wd-button/#findComment-2592399
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
