my well known blue one is sold as i wanted to go street instead of track...
so i purchased this puppy
black factory manual rb20de non hicas non abs
ill write mods up later... heres pics how it is as of yesterday... front 5 stud and front rims + guard flare this weekend
Edited by Hella Flush
https://www.sau.com.au/forums/topic/139023-hella-flush-a31-rb20de-5spd-manual/
  • 3 months later...
i know dude! ive been workin flat out on it and im just so sore...
will do ti this weekend when i put my front sections in, 5 stud, 33 brakes and front rimsys... ill set ride height and allignment all round
exhaust this weekend asqwell as you can see stock one is almost hitting as it is
dont worry dude - everyone knows im the king of jap styling :laugh:
update front 5 stud done today...
need new master as brakes are heaps soft (33 gtst all round) and bled them 3 times...
front wheels on enxt week to complete the set
exhaust gets done tomorrow morning at 9am which is actually 5.5hours away from now lol
rebuilding the driveline will begin next and more susp work
s14 hubs
s14 stubaxles
r33 rotors
r33 calipers
cefiro lower control arms with r33 balljoints pressed in (r33/s14 same balljoint taper/assembly and stub axle/hub)
dont use s14 or r33 lower control arms... extra 10mm in track can play with camber adjustment and be abitch thus i opted to use stock arms
pedders suspension charged 100 bucks for brand new balljoints to be pressed into my arms
40 a balljoint and 10 per side to press
one thing which im wondering about your setup konect is r33 dont use normal front coilovers like the silvia range... due to being irs they mount like a rear set dont they? makes me think you cant use r33 lower control arms and/or stub axle... would need to swap for s14 items
supposedly can use r32 front hubs slotted into standard stub axles also... thats what i did with my rear atleast - used z32 rear hubs slotted straight into my factory stub axle using factory drum handbrake setup... then slotted the brakes over
back on track
update on my car
5 stud completed yesterday as above... front section brand new coilovers come out of the gfs s15 and into my car tomorrow so i can have my full set back
exhaust was cancelled this morning as my guy called in sick to work so couldnt do it... rebooked for tuesday
got some interior bits i was missing today and installed - airvent surrounds etc
copped some gutter rash on my drivers side rear rim tonite at this ridiculously tight roundabout
attempted the white dial mod to dash cluster last nite
took 2 smokes straight and i had it done with all the green caps removed and reinstalled (did it in carpark whilst eating hj's as i always carry 3 toolboxes with me full of tools (just incase!))
only problem... they were a yellow tinge... so today took cluster out again and installed phillips ultravission hyperwhite/blue globes...
the cluster is now super bright - i love it... however it now has a green tinge due to the factory dials green coating... so im wondering how to fix this? it has been mentioned to use thinners on the dials to remove the green?
front rimsys should arrive this week also - already got new front tyres to stretch on when they arrive
also added some stickers today to rear quarters... pics up shortly!
s14 hubs
s14 stubaxles
r33 rotors
r33 calipers
Yeh I have all the parts off the R33 but was planning to use the S14 front hubs and lower control arms. But it seems you say that I can use the standard lower control arms if I get the new ball joint. Correct? So then I would only need the S14 hubs for the fronts.
R33 rears bolt on apparently. Mmmm drum handbrake.
its height man dont worry... now 5 stud is on it looks a lil better... slammed at front too just needs to come down at the rear
respray is on the cards... already lined up... but unsure when... its either going to be turbo conversion or respray... i know which is cheaper (respray) but am really hanging for some power to actually use the car
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
