This recent sydney heat has had an impact on the smooth/responsive feel of my car.
Obviously 9psi boost has turned into more like 7 or 8 due to the heat, which i expected.
I'm using the stock intercooler (R33 - 3inch full exhaust - pod - turbotech set at 9psi)
The car has stalled on cold start 3 times on the 3 recent hot days, and the idle was playing up a bit while driving, dropping way too low (will look into cleaning aac valve soon).
Also, the car seemed alot less responsive, less willing to pick up on demand, kind of running rougher.
Never had any of these issues before the heat. Since it's cooled down again, everything seems fine.
My question: Is all this related to the hot weather? If so, will a fmic fix this?
https://www.sau.com.au/forums/topic/139057-is-the-hot-weather-to-blame/
  • Replies 60
yeh, in hot weather my line turns into a freggin corolla.
lol great, take one skyline, some extreme heat, mix together vigorously, and you get one corolla.
what about the stalling? my car always starts first go, i barely have to look at the key and it's rumbling nicely.
but the last time (sat), i was cranking it over forever, and on the 4th attempt it started.
i had a cooler on my 33 and went throught the same shit munkeh... so i have a two part answer to your question:
a) cooler makes little, to no difference on start up problems... and
b) you should have a cooler anyways, can runs so much better with one
turboz just dont like the heat... i used to find that on really hot days, it just didnt have the low down pull i usually had
an intercooler wont help you much at all. its just going to act as a heat soaker when your in traffic. since your in sydney, this would be more then likely the case. on that note, my car also feels like poo lately especially in the 30+ degree's we've had here in the last few days.
k, well i feel a bit better now, knowing you're all suffering with me :(
so you reckon the cold start problems might have been related to the heat. maybe from the previous day's heat abuse or something?
best way to get decent performance in summer is a waterspray intercooler jet. I have had great sucess with this.
I had a cefiro a couple of years ago that was set up for drift and saw a lot of track work in summer and it was also my daily driver.
I had a temp probe lust before the throttle body to measuer intake temps.
When I first got the car in summer with the stock cooler I saw temps of 60deg + then I put the FMIC on and saw an drop of about 10 to 15 deg.
but I was getting pinging on really hot days. so I decided to fit a waterspray system. All it really was was a windscreen washer motor/bottle with a hose going to the front of the cooler that directed 4 water mist nozzles on the front of the cooler. It had a check valve to stop it from siphoning out of the washer bottle. It was triggered by a pressure switch from an old washing machine that was set to 4psi.
As soon as you started to boost it the system would switch on and spray water in a fine mist onto the cooler. It was amazing it dropped intake temps to about 5 to 10 deg above ambient. and stopped the engine from pinging. I am going to do the same mod this summer on my new car and will do a writeup for those interested. All up it cost about $70 for the patrs and a bit of fiddling but its a really good mod. you just have to remember to fill up the bottle every time you fill the car as it only lasts for about a 300k's with spirited driving on a small scource.
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
