This recent sydney heat has had an impact on the smooth/responsive feel of my car.
Obviously 9psi boost has turned into more like 7 or 8 due to the heat, which i expected.
I'm using the stock intercooler (R33 - 3inch full exhaust - pod - turbotech set at 9psi)
The car has stalled on cold start 3 times on the 3 recent hot days, and the idle was playing up a bit while driving, dropping way too low (will look into cleaning aac valve soon).
Also, the car seemed alot less responsive, less willing to pick up on demand, kind of running rougher.
Never had any of these issues before the heat. Since it's cooled down again, everything seems fine.
My question: Is all this related to the hot weather? If so, will a fmic fix this?
https://www.sau.com.au/forums/topic/139057-is-the-hot-weather-to-blame/
  • Replies 60
yeh, in hot weather my line turns into a freggin corolla.
lol great, take one skyline, some extreme heat, mix together vigorously, and you get one corolla.
what about the stalling? my car always starts first go, i barely have to look at the key and it's rumbling nicely.
but the last time (sat), i was cranking it over forever, and on the 4th attempt it started.
i had a cooler on my 33 and went throught the same shit munkeh... so i have a two part answer to your question:
a) cooler makes little, to no difference on start up problems... and
b) you should have a cooler anyways, can runs so much better with one
turboz just dont like the heat... i used to find that on really hot days, it just didnt have the low down pull i usually had
an intercooler wont help you much at all. its just going to act as a heat soaker when your in traffic. since your in sydney, this would be more then likely the case. on that note, my car also feels like poo lately especially in the 30+ degree's we've had here in the last few days.
k, well i feel a bit better now, knowing you're all suffering with me :(
so you reckon the cold start problems might have been related to the heat. maybe from the previous day's heat abuse or something?
best way to get decent performance in summer is a waterspray intercooler jet. I have had great sucess with this.
I had a cefiro a couple of years ago that was set up for drift and saw a lot of track work in summer and it was also my daily driver.
I had a temp probe lust before the throttle body to measuer intake temps.
When I first got the car in summer with the stock cooler I saw temps of 60deg + then I put the FMIC on and saw an drop of about 10 to 15 deg.
but I was getting pinging on really hot days. so I decided to fit a waterspray system. All it really was was a windscreen washer motor/bottle with a hose going to the front of the cooler that directed 4 water mist nozzles on the front of the cooler. It had a check valve to stop it from siphoning out of the washer bottle. It was triggered by a pressure switch from an old washing machine that was set to 4psi.
As soon as you started to boost it the system would switch on and spray water in a fine mist onto the cooler. It was amazing it dropped intake temps to about 5 to 10 deg above ambient. and stopped the engine from pinging. I am going to do the same mod this summer on my new car and will do a writeup for those interested. All up it cost about $70 for the patrs and a bit of fiddling but its a really good mod. you just have to remember to fill up the bottle every time you fill the car as it only lasts for about a 300k's with spirited driving on a small scource.
    • The SS button head cap screw on the back? If so, good to know. I presumed it was there for basic assembly and nothing more.
    • Hello, everyone. I'm new to the forum. I have a 1989 Nissan Skyline R32 GTR. I have lost all power to the interior, including AC controls, the gauge cluster, turn signals, and windows. Stuff that still works includes the horn, brake lights, radio, and headlights. All fuses, in the interior and exterior boxes, tested good.  It starts and runs fine, just with no gauge power or anything stated above. No warning lights either. Things that I have tested: - Fusable link tested fine - No other fuses blown - Alternator good - IGN switch tested fine - With my power probe, I can backfeed power through the IGN pin to the plug on the back of the gauge cluster, and everything comes back on.    So my theory is something on the control side that sends the ignition power through the system isn't doing its job, or a wire is broken. (I would think that it is the ignition switch that would do that, but who knows?). The ignition relays don't fire (all relays tested good). So what tells them to fire other than the IGN switch?  I would really appreciate it if someone had some insight on this. I have tons of hours into this; I don't want to give up in defeat! I have the HD wiring diagram, but having all those wires laid out like that on one sheet of paper makes things pretty hard to follow.  Thanks for reading, and thanks for the replies.  Where should I look next? Thanks.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • And gone to a new home
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
