To get this cheaper, i need a minimun of 5people to order the same thing (except the waxes can be different)
most of the cheap stuff dosnt really get any cheaper..
example, carbon is $90, if 5ppl get it $75...
Waxes
1.ali-turko
carbonwax
2.
Alrightly, if you havnt heard of zymol befor is the best shizzle to use on your car, if you have heard about it then youre probably using it..
Anyways off the top of my head (because i cant find anyinfo to steal) everything in zymol is all natural which is a great start to knowing its not going to damage your ride..
They have products to help out in every section of the car..
This is thier generic site http://zymol.com/ its pretty lame, but dont let that fool you..
I work at a prestige smash repair (bmw,porshe,audi,Mercedes) and all we use is zymol..
I suck at trying to do this..
If youre unsure on want you need/want post here or pm me..
I can do a demo using the below for $70 if you dont want to buy it all..
If youre in melbourne, i suggest you pick up so i can show you how to use the products.
hand clay $25 (it says you need "le-lube" but soapy water is fine)
http://www.zymol.com/lehm-cla.htm
hd clense 8.5oz $53 16oz $80
http://www.zymol.com/hd-clean.htm
cleaner wax $45
http://www.zymol.com/onestp2.htm
http://www.reviewcentre.com/reviews59094.html review on the wax 10/10
and your car will come up gleaming..
Heres a short list of thier products..
solvents and restoring original moisture.
This kit contains a full-size container of each of the basic products that make up the zymöl Automotive Enhancement System: 8.5 ounces Clear, 8.5 ounces HD-Cleanse, 8 ounces wax (your choice, see wax chart),
wax applicator, pre-wax
applicator, towel, and 5 ounces
of Vinyl or Leather Treat
(please specify).
I recommend these, as it comes with a bit of everything, but they are $250
Complete™ Kit
This kit contains everything you need to give your car its ultimate shine: 8 ounces wax (your choice, see wax chart), 8.5 ounces Clear™, 8.5 ounces HD-Cleanse™, 8.5 ounces Vinyl™, 8.5 ounces Treat™, 22 ounces Brite™, 8 ounces Wheel Coat™, 2 ounces Detail Wax™, Horse Hair wheel brush, Detail brush, (2) wax applicators, (2) 100% cotton towels, and (2) pre-wax applicators, all in a sturdy post-consumer plastic carrying case.
Carbon Wax
Zymöl waxes are actually "zymes" that turn into wax when exposed to air during application on your paint surface. Creame Wax, for light-coloured cars, contains 33% Brazilian No. 1 Yellow Carnauba by volume; Carbon Wax for dark cars and Zymöl’s waxes for specific automotive marques: Saab, Volvo and Japon for Japanese cars contain 37% Carnauba by volume.
Aerodynamic body components such as bumpers, air dams and wings are made of fiberglass, PVC, polypropylene, polyurethane and ABS. The painting process on these parts requires a paint with a vinyl base for flexibility (a "flex agent"). Solvent and alcohol-based treatments cause the paint to lose this flex agent and become brittle. zymöl Detail is an oil-rich feeding product that restores original moisture and seals the paint with a hard-cured finish.
HD-Cleanse removes light oxidization, moderate scratches, accumulated road film, tar and acid rain deposits, renewing your original paint lustre.
lear is a unique combination of pure tallow, pure coconut essence oil conditioners and lemon extracts to gently clean and care for
your car.
The oils from foods, your skin
and your pets create an adhesive for dirt, road dust and airborne pollutants.
Zymöl Fabrique is a phosphorous-free, solvent-free, carbon dioxide-charged
dry-wash fabric cleaner designed to remove
foreign matter and oils from seats,
carpet and cabriolet tops without
disturbing the inherent properties of the material
wetsponge.gif wow the pic makes it look horrible, but its nice in real life
The right Sponge makes a big job easy. Molded without paint killing silicone, this forever supple, heavyweight sponge drenches your car in soft frothy bubbles, helping you slide dirt and foreign matter away from your paint with minimum effort.
ot all towels are created equal. Every domestically made towel is washed several times by the manufacturer to remove excess dye. Unfortunately, this leaves the towel looking limp and used. So, manufacturers then "size" the towel to make it look more attractive and new again. This "sizing" process uses a starch and silicone mixture that will scratch and contaminate your paint finish.
English Cod Tanning is Expensive.
So we manufactured the correct alternative. Our synthetic Chamois absorbs and squeegees like leather without removing wax.
The Wash Caddy™
This combination makes the chore of washing your car quick, simple and fun! Tell the world you care about your car.
Our Wash Caddy™ contains an oversized silicone-free wash sponge, wash valet, and 5 gallon wash bucket.
pimping bucket
Soft seals, those around doors, hoods and trunk lids, present a number of problems. They are constantly being flexed and crushed while being subjected to hostile environments.
zymöl Seal is derived from glycerin, a
natural plant anti-oxidizing agent. Seal notably prolongs the useful life of rubber seals by releasing trapped
Acid rain, road silt and fallout are the enemy of paint. Water and zymöl Clear™ washes away the loose particulates but not the embedded pollution. The sun acts as a catalyst to help these paint-toxic pollutants penetrate and destroy your paint.
Lehm-Klay, a new Professional natural cleaner and conditioner for automotive paint, is a superior natural remedy for acid rain etch, moderate abrasions, bird droppings and light oxidation.
Lehm-Klay removes paint marring and soil through microscopic polishing and cleaning without harm to new or old paintwork.
The first "real" cleaner-wax. Because of petrol-solvent limitations cleaning and waxing combination products have had a history of either cleaning or waxing but not doing both very well. We have developed an all natural Cleaner-Wax that we are
very excited about.....because it works! Uniform polishing agents clean and repair minor paint blemishes, scratches and abrasions without petrol solvents while imparting a brilliant coat of natural waxes to protect your finish.
https://www.sau.com.au/forums/topic/139119-eoi-zymol-products/
u no im intrested in the carbon wax
yep i know, but i dont recommend it unless your car is absolutly immaculate..
Youll get a better finish with a klay and cleaner wax..
but the carbon is the same price as japon $90.
Interesting cleaning gear
Full kit looks awesome, is there any sort of saving buying the full kit than individual products?
lol, pimping bucket :)
well you get bigger portions in the full kit, and a nice case.. its around $350 tho (ill have to check)
I'm currently using zymol cleaner/wax and although good I've found its a bitch to buff off by hand! Am I doing it right or are u supposed to use it with an orbital buffer or something..??
I did my bonnet one afternoon and gave up on the rest of the car...needed a lot of elbow grease to buff. Any advice?
I'd be in for sure.
I need a wax for a 15 year old paint job. At the moment I'm using Mequiars Tech Wax, but always wanted to try Zymol. The car is a dark blue pearl, would the Carbon or Cleaner Wax be better?
Did you read the instructions on the bottle? I bet youre letting it dry, hence its hard to come off, and makes a mess, also you probably have impurities on your bonnet, fall out, if you park near a train station youll have rail dust..
youre ment to wax a 2foot area and wipe it off basicly straight away, it makes no mess and comes off nice, after that give it a rise and chamois, looks a million bucks..
I'd be in for sure.
i dont recomment carbon for any dark cars unless its just been repainter, because its just a hi gloss wax, it will show all the scratchs and swirl marks..
Yes you can get rid of the swirls, and carbon it, but cleaner wax is a better choice if youre lazy, it may not have a high gloss as carbon or the other waxes but its good because it hides swirls and scratchs..
clay/hd clense/cleaner wax, car will look great..
Do you sell the sponges by themselves? I'm up for some new products soon and want to try this stuff. Can u run through what i'd need to go from start to finish of washing to top coat of wax (i've been doing 1 coat synthetic 1 coat natural) and then stuff i'd need the next time i went to wax it (so if id need to remove the old wax layers etc)
Hope that makes sense :)
Is your price cheaper at all than rrp?
e.g. as said above - carbon wax is 90 at autocheap. You had it up at 90$
Perhaps, would you be able to run it like a proper group buy above and say the price that you can do it for, and what quantity is required?
I'm interested in the clay - e.g. is 25$ the rrp? or is it a special price? how many buyers are required etc.
Does it include postage? is it pick up? from where? etc.
hey buddy, i said 5people need to order the same thing for the price to go down, so the carbon will be $75 with 5ppl in..
its also pick up from melbourne unless you want it shipped
  • 4 weeks later...
can i get a price on the following:
Complete Kit - Carbon wax
Cleaner Wax
Chamois
Sponge
Clay Bar
Also, how much of a difference is there between the normal Carbon Wax & the Concours wax?
