got 95 r33 with airbag
how do i get the steering wheel off
or get the plastic part that goes around wheel behind front horn cover
got all other covers off around area
just appears to be 2 little screws inside wheel that hold this cover on and there no room in there to unscrew them
does the front horn panel come off??
thanks
https://www.sau.com.au/forums/topic/13913-removing-steering-wheel-on-r33/
I don't know for sure but it looks very similar to what was on my previous VS Commodore with airbag. If that's the case, then the whole front panel should come off with a couple of screws holding it down from behind. After the steering column should be visible, just undo the nut and use a puller to get the wheel off.
Oh, disconnect the airbag wire before you do all this, you don't want it exploding in your face!
You should disconnect the battery before to starting to make sure the airbag doesn't go off in your face!
Also if you're planning on fitting an aftermarket steering wheel and boss (and your car has HICAS /ABS) then you'll need one that is suitable for HICAS equiped cars...
Wish I could take my steering wheel off and take a closer look at it.
Everytime that I turn my wheel more than about 90 degree's its like their is a loose bolt or something inside and it feels from the bottom to the top then as i turn my wheel back it falls from the top back down to the bottom again and it really annoys me.
i got that problem
thats y i want to get the cover off so i can fix it
it just started making that sound some 4months ago
and last weekend i said enough is enough
ive found wat the problem is
seem like a rod that runs across whell that has 2 turning things on each side and its loose or something and that why when u turn it at specific point it making that dong sound
only problem is i cant get cover between steering wheel off to have a proper look
might take it to my mechanics later in week and get them to fix it if no one else can help us with this issue
Im not sure about the air bag wheel but on a non airbag wheel the front horn button cover just pulls off, there may be some screws behind the wheel to remove the airbag mechanisim just look behind
The most common steering wheel rattle is the horn button plastic ring broken caused by bashing on the horn to hard.
Yep, vouch for the horn cover thing...just posted a question in the Vic Forum regarding that.
I have non airbag, took one screw out, phillips head, from behind the steering wheel...then just pulled..as with most Plastic parts on the skyline it just clips out. The screw was really annoying to undo because you can't see behind there, and it's a small screw but a big hole...(no phallic intentions)
I had an annoying rattling in the steering wheel when I turned corners and it was the plastic thingy behind the horn pad, it must be really fragile beacause I hardly use the horn. I removed all five pieces it had broken into and now all is well, but I can't find a new one...
Paul
hey guys,
i replaced mine at autosport (i think thats what it was called, in kirrawee). the one thats affiliated with just jap. the guy there took the wheel off, replaced with my after market one and re-wired the horn at a very good rate.
the main issue with the one i had (series 1 with air bag) was that there are 2 little screws on the column itself (you have to pop the cap things off it before you can see the screws, use a little key or something). the screw was a weird star shape (apparently common for skylines) but mine was worse coz it had another little hole thing as well (very hard to describe).
but all the guy at autosport did was get some tool he had and removed the wheel... etc etc. i dont think you can use any std type of screw driver.
hope this helps,
Nav
i know wat to do as i did this just a few weeks ago....there are star shape style allen keys thing right...they are gold in colour....go to a tool shop and get a T50 size key or adaptor.....remeber its a star shape and u need it to have a hole in the middle for the bit that sticks out.......i didnt need to worry about airbag going off cos it already did in accident :)....if u need anymore help just let me know
fixed
i was going about it the wrong way
all u need to do is
get t50 screw, i tryed few shops like bursons etc
i wouldnt reccommend wasting ur time as they only sell them in a set and there like from $40
i went to my mechanics and borrowed theres
all u do is take 2 rubber panel covers of side of wheel
unbolt 2 gold screwa with t50
cover will come off
look and find problem
should be big block of metal with little rubber handles holding it
if u can fix it do that or just break it off like i did and problem solved
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
