  • Replies 58
IBM notebook is GONSKI !
added 6x self inking stamps (over $20 retail EACH) awesome for your business.
added Motorola battery.
added Belden ultra low-loss Twinax cable. Very rare outside of military & govt.
Home alone ?
feeling lonely ?
call me NOW
1800 FREESTUFF
Edited by BigDatto
Also have a vintage Marantz model 6300 turntable. This was primo Hi-Fi gear in it's day, and is very collectable. Good examples go for $USD 500 (check ebay) Not giving this one away, but will consider offers over $100. works fine & sounds great, could do with a better cartridge. Stylus & cart are tip top.
Call with your offer
0424 569772
Wells.
*EDIT* needs one new foot. Micro Seiki feet are identical & you can still purchase these as NOS (that means new old stock, ricers) :0
Edited by BigDatto
ADDED: Xbox steering wheel, MadCatz brand, better than most of their stuff, works 100%
First in, best dressed !
0424 569772
Wells
thnx for the xbox faces / steering wheel
the stamps and the nokia phone
cheers
[/quote
Always a pleasure. Thanks for keeping your appointments, J & Sam.
ADDED: HUGE pile of magazines. Including but not limited to:
Auto nostalgia
Motorsport (the British mag, excellent for motorsport historians)
Used Car buyer's guide
Motor
New Zealand Classic Car
High Performance Imports (at least 15 copies)
Street Machine
Fast Fours & rotaries ( dating back to 1993, when it was the best tech mag. Today it's rice & bling)
Hot4's (same - was great, today is a fashion parade)
Wheels (what was I thinking?)
BRW
Drift Battle
Gaming mags - PSX, PS2, Sega Saturn etc
Speed
Future Music
Computer Music
Overlander
Modern Boating
etc
etc
etc
One of my personal faves, FF&R tech tips. Full of awesome DIY stuff from Julian Edgar, the DIY tech guru.
Now, you're welcome to this Lassiter's reef of information for nix under the following condition:
You take the lot; NO PICKING & CHOOSING !!
Be quick!
Wells
0424569772
Edited by BigDatto
Attention Muso's & wannabe Quincy Jones: the Home Recording Handbook. Everything you need to know to set up a home studio. geddit NOW !!!
0424 569772
Wells
Jason, I found another good Mini book, "Mini Cooper & S" by Nigel Edwards.
Colour, data & detail on the road & rally cars 1960's to 1990's.
Call if yr keen
Wells
ADDED: Mission/Cyrus M72 bookshelf loudspeakers. 6" woven glass composite woofer, inverted silk dome tweeter, Biwireable. partner with quality equipment please. Pussycat decided to sharpen her claws on one, so its trashed. ;);):rant: The other is fine. Cosmetically excellent. Magnetically shielded - safe for yor telly. Replacement drivers would cost substantially less than replacing the speakers entirely. Will swap for a good copy of "101 uses for a dead cat" :(;)
Crestmore Enterprises in Hornsby is the Australian agent for Mission/Cyrus.
Be very quick on these, nobody "gives away" quality Hi-Fi gear. ('cept me of course!) :)
Wells
0424 569772
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
