Hey all,
tried searching for a while but couldnt turn up any definitive answers......
I wish to install a Bosch 044 pump in my R33, it's advertised as an external pump, but is it possible to do it intank? If anyone has done it or knows of a DIY thread on it it would be great!
Cheers, Bart.
Edited by bj_dove
https://www.sau.com.au/forums/topic/139190-bosch-044-installation-r33/
yeh its possible i installed mine about 3 weeks ago..bosch 044 mounted intank in an r33 gtst
its not hard at all, just read those threads on how to get it out, but you dont need to buy any extra fuel hose or anything like that. i needed to get a fitting to replace the one on the top of the pump from pirtek which cost me $48 all up and a 3" hose clamp to secure it to the standard pump cradle..also needed a fitting machined from pirtek so you can use the standard fuel pick-up/filter on the bottom of your 044. if you want part numbers i can dig them up tonight..also to hook the power and earth wires to the pump from memory was a 5mm and 6mm fitting.
if you could shoot me the part numbers it would be awesome! did u manage to take any photos of the 044 on the cradle while it was out by any chance?? :P
Cheers
Now im gonna be a real pain in the arse!
If i decide to go the route of a surge tank, do i simply run the fuel return line to the tank, that way the surge tank wouldnt be under pressure, or do i just return it to the surge tank ready for use again?
Cheers :P
Cheers :P
use std pump as the lift pump.
depending on how many fitings on your surge tank as to how you do it.
i used the return from the engine into the surge tank, and fed the overflow on the surge tank back into the fuel retun line on the fuel tank cap.
less mucking about that way i found
Righto, i get ya! If i can fit the 044 snugly intank ill go that way, to save on noise, etc., as it will be mostly a street car.
A few peeps on here have been saying that 044's dont come with a check valve standard, but i can clearly see a spring inside the outlet fitting, im assuming thats it?
yes they have a non return valve standard, but its to suit the wrong fitting.
go into pirtek and get one like what i have used and it works a treat.
yep, come with a banjo style check valve .
bout 50 for a screw in check valve, plus the push on fitting it will need.
Sorry mate i must have thrown the receipt out so i dont know about the part numbers but as someone said just go into your pirtek store and tell them what your doing..as you can see from that photo all you need to do is clamp the pump onto the cradle, widen the gap at the bottom of the cradle so the pump sits a bit lower, cut off the little metal fuel line that originally connected to the standard pump so its not in the way, and use the standard fuel line to connect to the top of your new pirtek fitting..
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
