Flying Performance International is the only official online Hybrid & SABER dealer
Flying Performance International official website www.flyn.com.au
Check out the Hybrid & SABER official website at www.powerdigger.com
SIMPLY FOR THE REAL MAN WITH THE INTENTION TO WIN!!!
* For the serious enthusiast and maximum performance only
* Best suited to high performance applications
* One of the BIGGEST Blow off valve in the market
* Maximum flow with extremely LOUD noise
* Features full CNC machined ALLUMINIUM body and piston, HIGH-QUALITY seals, THERMAL AND PRESSURE TESTED springs
* Anodised to prevent corroding
* Spring tension adjustment via "SIMPLE WRIST ACTION" for fine tuning different boost pressure (no spanners required)
* Supplied with 2 weld-on adapter to suit alluminium or stainless/mild steel piping, also allen key is provided for the grub screws
* Comes with a STEP-BY-STEP PICTORIAL INSTRUCTION for easy installation
* Style, performance and awesome sound
$64 delivered
Payment Instruction
Postage & Handling = $15 freight Australia wide
PAYMENT TO : FLYING PERFORMANCE INTERNATIONAL PTY LTD
ST. GEORGE BANK LIMITED
BRANCH NO. : 112-879
ACCOUNT NO. : 065766824
PLEASE you must give the bank your forum user name as the description of the transaction. That way it shows up on our bank statement with the amount you have sent us. So we can match your order with your payment otherwise there may be a delay for us to match the payment to your order!
After you have made the payment, please you must e-mail us with your payment date & amount, your name & postal details.
Once we receive your payment, we will inform you and send it at the same time.
It will be packed and sent securely in boxes or bubble padded bags for best protection.
Optional extra
7f_1.JPG $48 SABER stainless steel mesh air filter
41_1.JPG $180 SABER 60mm electonic smokey lens gauges
59_1.JPG $259 SABER GDB WRX /STi air intake kit
cf_1_b.JPG $49 HYBRID a set of 10 HOSE CLAMPS, 2.5", 2.75" & 3"
f0_1_b.JPG $19 HYBRID SILICONE HOSE REDUCER, We have 3" - 2.75" / 3" - 2.5" / 2.75" - 2.5", you tell us the size you want.
0a_1_b.JPG $17 HYBRID SILICONE HOSE, 3" / 2.75" / 2.5" / 2.25" / 2" / 1.5" STRAIGHT HOSES
53_1.JPG $7 FLYING SILICONE VACUUM HOSE
05_1_b.JPG $49 Flying boost controller
7b_1_b.JPG $29 Flying boost controller
5c_1_b.JPG $199 + $25 extra freight
4e_1.JPG $33 FLYING 6 meters EXHAUST HEAT WRAP
06_1.JPG $149 Flying sr20det turbo manifold (SOLD OUT)
0a_1.JPG $189 Flying Rb20det / rb25det turbo manifold
dd_1.JPG $149 Flying 180sx s13 r32 300zx camber arm
e3_1.JPG $149 Flying s14 s15 r33 r34 camber arm
b8_1.JPG $139 Flying GT wing
72_1.JPG $99 Bee*R PINAPPLE BUSHES S13 180SX S14 S15 R32 R33 R34 Z32
5d_1.JPG $75 FLYING S13 180SX S14 SR20DET SILVIA SHORT SHIFTER
26_1.JPG $79 FLYING SILVIA S13 180SX S14 S15 SR20DET TURBO DUMP PIPE
fe_1.JPG $99 FLYING SKYLINE R32 R33 R34 RB20 RB25DET TURBO DUMP PIPE
55_1.JPG $55 FLYING ADJUSTABLE FUEL REGULATOR
7b_1.JPG $25 FLYING OIL CATCH CAN
HSD Suspension
HSD coil-overs are used by 2005 Drift Australia champion Darren Appleton and many other prominent drivers in Australia. Now available only in the premium HR series, HSD coil-overs feature 55mm heavy-duty full-tapped dampers with 15-step damping adjustment. All models feature pillow-ball top mounts for easy installation and maximum control. Models with strut-type suspension also feature camber adjustment, while all models feature adjustable base height and spring seat height.
HSD coil-overs are supplied with spring rates intended for club-level motorsport, drift and street driving. Harder or softer springs are also available at just $100 a pair. All rates from 3kg/mm to 14kg/mm are kept in stock.
All HSD coil-overs come with a 12-month warranty against manufacturing defects.
NISSAN
S13 Silvia or 180SX $1549
S14 200SX $1549
S15 200SX or Silvia $1549
R32 Skyline GTS & GTS-t (GTS-4 available to order) $1549
R33 Skyline GTS25 and GTS25t $1549
R34 Skyline GT and GT-t $1549
R32 GT-R $1549
R33 GT-R $1549
R34 GT-R $1549
Z32 300ZX and Fairlady Z $1549
Z33 350Z $1549
TOYOTA
JZX90 Mark II, Cresta, Chaser $1549
JZX100 Mark II, Cresta, Chaser $1549
JZA70 Supra (Also GA-70, MA70, MA71) $1549
JZA80 Supra $1549
SXE10 Altezza and Lexus IS200 **NEW** $1549
SUBARU
GC8 Impreza WRX (MY94 to MY00) $1599
GDB Impreza WRX (MY01 to MY02) $1599
GDB Impreza WRX (MY04 on) $1599
SG5 Forester $1599
MAZDA
FC3S RX-7 (Series IV and V) $1549
FD3S RX-7 (Series VI to VIII) $1549
MITSUBISHI
CP9A Lancer Evolution (IV to VI) $1549
CT9A Lancer Evolution (VII on) $1549
HONDA
EG Civic $1549
EK Civic $1549
DC2 Integra $1549
DC5 Integra **NEW** $1599
AP1 S2000 $1549
For sure.
Our bovs feature full CNC machined ALLUMINIUM body and piston, HIGH-QUALITY seals, THERMAL AND PRESSURE TESTED springs
do you have the low style GT wing
Same wing just different mounts the low type
no sorry, we only make the high ones, as that is what the trend is going at the moment.
V SPEC RRP AUD$350+
Flying Performance SPEC S Alloy BLACK GT Wing
53" (1.4m) length, 7" (18cm) height, 15" (38cm) between mounting legs
* UNIVERSAL FIT for most cars in the market. Good for both sedan and coupe.
* Hi-tech styling, LIGHT WEIGHT but STRONGER in structure than fiberglass and ABS plastic.
* Street cars don't have slicks tyres, this GT Wing makes it up with extra downforce
* Made specifically for hard tuned street racers to provide extra stability and tractions for all cars
* No painting required but PAINTABLE easily without any sanding / preparation (both 2Pac, acrylic).
* EASY DIY INSTALLATION, you can install the wing in as little as 30 mins.
* Don't be the last one to get it in the block and have the FAST and the FURIOUS, TOKYO DRIFT look.
Flying Performance HYPER POWER - STAINLESS STEEL BOOST CONTROLLER. DONT MISS IT!!! Full Boost Faster, Harder and Longer. Attractive mirror chrome finish for an excellent engine bay dress up.
IN-CABIN OR ENGINE BAY MOUNT
With our step-by-step instruction manual, DIY in 5 mins
FLYING PERFORMANCE INTERNATIONAL is the latest manufacturer of turbo accessories. Our products are not only affordable and easy to install, but with finishes to appeal to all turbo fans. Although we currently only offer 3 atmospheric turbo blow off valves, 1 plumb back turbo off valve and 1manual boost controller, the development of new products is always under way.
Unleash the potential of your turbo with our FLYING Boost controller. Flying Performance boost controller will bring your turbo to full boost faster, harder and longer at lower RPM to reduce turbo lag. This results in full power much sooner, which in turn lowers your 0-100km and 1/4 mile times. Boost feels VERY crisp and responsive. Flying Performance boost controllers are of no question the most cost efficient and effective way to increase your turbo car’s performance to the threshold of your turbo’s capacity. The boost pressure is fully adjustable by turning the Boost Dial adjustment screw at the top of the unit, while referencing from your boost gauge.
KKR Turbochargers offer phenomenal performance at a very modest price. Built using the most advanced German equipment, they offer exceptional reliability and come with an industry-leading 6 months warranty from Australian distributor Otomoto, conditions applied under the company policies of Otomoto.
KKR-480
Suitable for larger 2.5–3.0L engines, this turbo features a twin-entry T3-size exhaust flange, which is also suitable for normal T3-flange manifolds such as RB25DET or RB30ET*. Rated at 480hp, it uses the same compressor design as the KKR-430, but a larger turbine and housing better suited to high-boost applications up to 20psi. It uses a 2.75in V-band flange for the exhaust outlet (V-band and flange included).
Tested by Croydon Racing Developments on an RB25DET engine, it produced 263kW at the wheels at 19psi. The standard internal wastegate is designed to hold 16–17psi.
The turbo will need minor adjustments such as rotating the housings, modification of the actuator and so on to bolt onto the engines listed.
