Hey guys, just bought some fibreglass gtr guards for my r33 gtst....im planning on keeping my front guards the same...so x8.5 rims would be the max ill go......but with the rears, im going all out, to create a hybrid skyline look, ill be getting the gtr guards soon, and have it moulded asap, and resprayed.
now i need to figure out how wide a rim i can go with the gtr guards, and will it effect handling having say 8.5 fronts, 10.5 rears????
Ive also got thr GTR guards on.
I had to lip the old guard and bend it out to make it fit bigger wheels. And also cut off some of the lip on the gtr guard
Im running 18x10inch with 265 and a 2 inch spacer and the tyre sits about 2 mm from the gtr guards lip.
If i were you i wouldnt bother with the GTR guards, its quite a big job getting them molded on.
the guards i got were from topstage in Melbourne.
They are good guards if you just intend to rivet on, but if you mould it on, its quite a labourous task and really quite expensive at $400 a pair considering you need to cut off half the fibreglass guard to blend it in properly.
I moulded them on myself and at the same time also made it wider above the crease and from the door, because the guards are only marginally wider than stock.
It has cost me roughly $500 for the guards and materials with a solid 2 days of work.
Ive been qouted by several shops and they were all above $1000.
I will post up pics tommorow of the early stages of the guard moulding and then the finished product wen i have a digi cam.
Pffffffft....
GTR Guards + Moulded Flares... the bottoms have now been modified to blend intot he sideskirt/bodywork. The rears will be done in 3 - 4 weeks, PM me if you want update pics.
Sif do shit half assed ahahah 13 inch rims ftw!!!! (wide)
How did you attach them to your quaters mate? screws? glass?
Most of the bog you see was sanded off, you need to use bog regardless for a seamles finish and strength.
The fibreglass guards was chopped of either side to allow for a blend.
Then the metal was roughten up and the lip rolled and folded out.
Sikaflex the guard on and screw in.
When sikaflex dries remove screws.
Scuff the surrounding area to bare metal
Then fibreglass was then applied to the area (between the guard and the add-on guard).
Scuff up fibreglass.
Apply good high viscosity filler over the fibreglass and joint and wherever necessary to blend.
When perfect High fill
Pffffffft....
Go the torana flares :S
Nothing looks worse on a skyline IMO
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
