you mean this one?
S&S engineering of automobile engineering special company (head office: Yokohama city) October 5th of 2000, using Internet, it announced you sell the remodelling used car of the Nissan Motor Co., Ltd. skyline with quantity limitation. As for start of sale at October 25th noon, Web sight (http: Only the //www.mypower-buy.com/) accepts with. As for sale quantity first-come 32 unit, as for price 4450000 Yen.
The Nissan Motor Co., Ltd. sold the based vehicle, from May of 1989 to August of 1993 "Skyline GT-R (BNR-32)".
It hits to the 8th generation of the skyline, in the present old car market popularity is high. The car which developed to 7th generation from the first skyline S&S engineering takes charge remodelling. According to the spokesman, "It is not the manufacturer oriented car, the hand was inserted in the skyline for the customer that we are wanted this. Without increasing price, you took the new sale method in order to sell, of using Internet ", plan intention has been explained.
As for remodelling, the part which is related to running such as engine and underside. It placed the engine in the BNR33 new item and changed, rewrote the ROM of the computer ECU for engine type control. The suspension part and the like was exchanged to the individual development part of the S&S engineering, installation rigidity improved. In addition, in order to raise body rigidity, it filled up the urethane type foaming material inside the side sill which is the important component of the body framework.
As for product name "BNR32 S&S Limited Version 1". In 3 types, white (10 units), the silver (10 units), gun metallic (12 units) you prepared body color. Automobile delivery has planned from December 1st.
Note: I edited the untranslated and the non sensical parts out. THat should make a lil more sense.
  • 17 years later...
On 13/04/2003 at 4:34 PM, funkymonkey said:
you mean this one?
Crazy old thread.... funky, where did you get the info from?? Would like to see the original source
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
