Just put the lightweight shockproof redline oil into my gearbox today. Now I can easily change to 2nd gear when the car is cold. But, I feel crunches for 1st, 2nd and 3rd gear, even when the car is warm. I think that it's worser than before. The crunches is absolutly noticeable.
The old oil that drain out from the gearbox is something like auto transmission oil.
What happen to my gearbox that react with the redline oil like this? any ideas?
:shake:
https://www.sau.com.au/forums/topic/13926-i-feel-worser-with-redline-oil-why/
Give it an easy 1000km+ before you make up your final decision on the Redline Oil.
For the first few days I was like "mannn i paid $100 for this stuff".... but now 5000+ km on and its the best $100 I've spent on my car.
yeah give it a good 1000km or so.
i used to get crunches into 2nd, they went away after about a week of driving after putting in lightweight shockproof. then about a month later, shifts became nice and easy, i have a short shift kit and shifts used to be really tight, too tight, now its just nice.
Yes, maybe the clutch adjustment problem. Everytime when I change gears, I will depress the clutch pedal all the way down. But, I only need to release it a little bit and the clutch start to engage.(car start to move)
And I found that the clutch fluid level is in the middle of the "max" and "min" mark. Should I put more clutch fluid in it? And what sort of fluid should I use to top up? Can it mix with different brands?
Or should I change all the fluid? if so, how to do it?
Thanks!
What I tend to do as a standard to my car is that " If the item and or fliud is unknown best to change it with a known item."
This way I am able to control what goes into the car and not to worry anymore. In the case of clutch and brake fliud fresh is best naturally. If the fluid has been sitting around in the garage or in a car for a few years they tend to absorb water leading to corrosion in the lines down the track.
MoonButt
  • 1 month later...
Hmm, perhaps you should have used Redline MTL or MT90. They are the ones that were designed from the start to give you better shifting, not Shockproof (even tho it does a good job too).
If it was ATF, it does give good shifting being really a hell thin viscocity, but it ****s up your box pretty badly after a while, because ATF does not contain the proper extreme additive protection that gears require.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
