Hello all,
On the freeway tonight going slightly up hill I put my foot down in fourth gear.
As increasing speed the car started to jerk like a mule and the engine light flickered on and off for about 2 seconds.
Looked at the PFC handcontroller and had 75 reading on the knock sensor.
I have been having some mis-fire problems and it has lead me to believe I have a faulty AFM.
Just wanted to know if it could be something else ie TPS(Throttle position sensor)?
Any ideas?
Thanks in advance
Tekin :)
https://www.sau.com.au/forums/topic/139275-knock-sensor-went-to-75-help/
have a read of the powerfc faq in my signature
covers all of the common questions and howto's for working with knocking problems.
i don't believe its a any of those and just a few points have some timing thats a bit too advanced.
in the warmer weather its knocking a bit more and also when you place the car on load, typically when rpm is low and you up are going up a hill youll find via map tracer
that you may be going into map areas that you dont often go into, or that haven't been tuned correctly
as its hard to go over the entire map on the dyno and cover all scenarios, so it could just be 1 or 2 spots with a bit too much timing
Thanks for the replies boys,
New Pump,new regulator,new coils ,new plugs..........
I do suspect it to be tune or Afms playing up.
Still missing everyday even after earthing the ignitor.
But then again could be a few things.
:laugh::woot:>_<:glare:
MAIN MENU
SETTING, IGN/INJ
PRESS DOWN 3 TIMES
ADJ for IGN COR will change to -3
Try and drive around and see if you can replicate the knocking / misfiring.
When you power the car off this correction goes back to 0 (zero). This is by design and how its meant to be. It's here as a test/tune mode and not meant to be a permenant correction method.
MAIN MENU
SETTING, IGN/INJ
PRESS DOWN 3 TIMES
I will give it a go tonight on the way home and in the morning tommrrow.
Thanks Paul........just about to ask you what number in the FAQ...bit confused. :D
yeah whilst there is no "heres how to temp ign adjust" in the FAQ its covered in there. the problem is theres no english manual thats upto date so you either have to use the old school rx7 english manual or the japanese one
-3 means 3 degrees retarded timing
+3 means 3 degrees advanced timing
to help combat knocking, you can try and take out some timing (retard) to see if it takes away the knocking (usually does). try -3 which is 3 degrees retard across the whole map
I've had readings of 95 knock, but no miss. So how does a reading of 75 end up with a miss?/? You have to be rattling your motor to bits to get a miss when pinging. Guessing here, but I'd reckon readings heaps higher than 100. I've had motors where I have had it, and they where knocking very loud, like a rattle.
By the way, you won't do any damage as long as you:
1. Don't hold it there, or push on.
2. Get it fixed promptly so that it doesn't happen again.
3. Use a trailing throttle when going up steep hills etc keep the load off the car [although if you retard the ignition by 3 degrees then you'll have to still try it again to see if it's fixed it].
I'd be interested to see if it solves the whole problem. Maybe the 'lean out' has shown up another fault only showing up under stress?
I've had readings of 95 knock, but no miss. So how does a reading of 75 end up with a miss?/? You have to be rattling your motor to bits to get a miss when pinging. Guessing here, but I'd reckon readings heaps higher than 100. I'd like to learn.
The Op's has been having a miss problem; likely to be related to ignition. Your ignition system clearly is perfectly fine and your det is simply too much ign. :D
As I mentioned with shagged coil packs on 2 different cars I have observed an increase in knock over what was before a perfect low knock tune in all conditions.
Most likely not the case here and most likely just a tune issue. But I thought it would be usefull to mention it. :)
75knock really is too high, might be worth taking the car back for a touch up as a load condition may have been missed when it was on the dyno. It is difficult to simulate road conditions on a dyno; which is why its so important the tuner takes it for a quick spin. From what I've seen the dyno tends to miss partial throttle on boost load points and low rpm high gear (up hill) lugs where it makes reasonable boost; even though on the dyno we did hit these load points on the road it was 'just different'.
also tekin, when you are seeing these knock levels what is airtemp under monitor? you can set ign retard in the PFC based on airtemp's but its only for 70, 80, 90deg plus. so if its 55deg theres no correction
Thanks again guys for the remarks.....
Set back ign as paul indicated......car runs smoother and has not missed tonight.
Even going up hill i planted it and all was good...excellaration came on nice and strong.
Paul, can I set back the ign by -2degree permanently and see if it happens again?
Should I use one of your saved tunes instead and modify it to my mods?
And has the tune been conducted in colder weather and this is why this has happened?
Lots of question...... :(:):(:):(:):O
    • My plan is to go the pink option. But still add the 4th fitting near the oil cap and just cap it off for now.  That way I can add 2 extra to the sump and have 4 dedicated breathers/drains if I ever remove the sump for any reason.
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
