Hey guys i just want to find out from you guys who have the same car (and only you please) with the standard pump, how long it primes for in the morning or after many hours of not running. If you don't start the engine when the ignition switch is turned to 'ON' how long do you hear the pump prime for? Is it very loud? And lastly do you ever hear the same prime noise for a very short time (1 second) during prolonged idling? ... memory this too is only after the first start in the morning or after many hours as previously mentioned.
Many thanks,
Deren
Yeah cheers for that mate. How about the prime during idle?
BTW just realised your after a nissan boot badge, i dont think i will be using mine anymore so its yours if you take me off your bad trades lol!
Edited by Godzilla32
Many thanks,
Deren
The sound came on due to lack of lubrication in the fuel pump, you can either put Redline SI-1 in your petrol tank or buy some ashless motorbike 2T, added 50-100ml and it will do the trick.
Edited by Trex101
Not on the GTR. I just cleaned the TB on my Mazda's KG 2.5L V6 and it ran like crap quite some time... next time I wont be lazy and I'll take the TB off rather than just spray all that carby cleaner down its neck :)
Is it a tough job? I'm sorry about dragging things off-topic, but my plan is to clean the IAC, clean the TB and then if it is still high I'll adjust the trim pot on the ECU. I'm pretty sure it had an aftermarket ECU removed prior to export, so the problem could be there...?
Dont clean the throttle bodies, It wont make it any lower, only higher, the more you clean from around the butterflies the more air gets thru when they are supposed to be closed - Hence high idle. Prolly the idle control valve getting stuck. Good place to start anyhow :laugh:
Dont clean the throttle bodies, It wont make it any lower, only higher, the more you clean from around the butterflies the more air gets thru when they are supposed to be closed - Hence high idle. Prolly the idle control valve getting stuck. Good place to start anyhow :)
Very good point dude! Cheers
Thanks guys. Sounds like i have no problem then :)
Its not the attesa pump. There would be no need for it to operate at idle. Only works when you are locking up the clutch packs in the transfer case to provide front torque.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
