PUS16 - Do you have contact details for this mob sure cams? Can't seem to find anything on the net about them.
Sure Cam- 6 Rodgers st Kingswood 2747 NSW
Ph no- 02 47361742 Fax- 02 47363515 e-mail- sales@surecam.com.au
www.surecam.com.au
Speak to phil, top guy and really helpfull! hope that helps u out!! :P
www.surecam.com.au
Speak to phil, top guy and really helpfull! hope that helps u out!! :)
cheers
hey dude, when we built my 30/25 and used an aspirated head we used the aspirated cams and made 465bhp on 27psi but with a massive drop off top end! So we got hold of a set of 26 cams and had them ground by sure cams so as we could still use hydraulic lifters and also used adjustable cam gears and made 602bhp pump fuel with 29psi. all with standard inlet, throttle body..... (basiclly a completely standard head with cams and camgears)!!
pm me if u want any info...
nath
Hey mate thats good power show us your dyno sheet
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
