I've checked all the fuses and every cable seems to be connected....
does anyone know a good Line sparky i can go to???
thing is all other dash lights work fine... i'm getting sick of driving at night with my phone light shining on teh speedo.
teh suxor IMO
kthnx
https://www.sau.com.au/forums/topic/139335-instrument-cluster-lights/
Maybe the bulbs in the cluster have shat itself? or the fuses in the actual cluster have blown?
Have fun taking the cluster out. :laugh:
I'm getting sick of driving at night with my phone light shining on teh speedo.
Not to mention illegal.
i dont know about 33's but on a 32 if the dimmer is unplugged then the dash lights wont work.. give that a check
happend to me, all other lights worked cept my speedo.. Locate the dim switch, it may be broken. I've just taped the 2 wires together.
Same here....
It still bemuses me that manufacturers ever bothered to put a dimmer switch in cars anyway.....
Why the f uck would you not want to see what speed your doing?
Anyway, check that, it's the most common problem.
The switch on mine was very tempremental....
Hey champ, had this happen in my s15 once, and thats cause the car runs so low, that the wiring harness to the fuse box got split, as the tyre scrubed out one of the wires which was the lights for the dash.
Have a look under your wheel arch at all the wiring harness that goes to the fuse box, this might be your problem :laugh:
FAIL!
that is 100% NOT correct, theres no such thing.. The wires are direct and do not come from under the car.
Rember that your car is a S15!
i dont have one ether.. hmm
marss, check the usual. cluster plugs at the back, there is 3 there. also the parker fuse in the boot. and of course, the globes them selves, might of had a short and blown them all? duno. but not hard to check for once the cluster is out. its not hard, easy enough to pull out in 15mins or less.
Mine didnt/doesnt have one. :)
I think they changed the law or something. :P
neither does mine... it's been taken out.. there is a high chance that a previous owner had taken it off..
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
