  • Replies 192
Hehe - I left the windows down most of Friday to get that 'new rubber' smell out. They do protrude a few mm from the guards, and I think there's a slight rub on the rears when you hit bumps at speed, but a -ve camber adjustment should fix that.
As far as lowering goes - yeah, the front could come down a smidge, but I don't want to lose any drivability with driveways, speedhumps etc. Will talk to Jeff when he does the camber/alignment - see what we can do :laugh:
Very happy with them though - the whole red/grey theme really works well. There's a guy in Sydney with silver 19" RS's on his blue Evo - looks good, but I think they are a bit too big. 18"s are perfect IMO. Clicky here for his car: http://forums.evolutionm.net/showthread.php?t=254987
We have a Murcielago for top end, and an Ariel Atom for bullshit acceleration. All cars (bar the RS4 Avant) will be in town soon, so I'll let you know the full fleet.
Newest one is a white 997 GT3, with a 575 Maranello looking like being on the books too. Should all pool up and get an SAU annual membership :(
But, back on topic...
I think the 18"s are big enough and am super happy with them. Some red (well... pink) locknuts going on today and the Golgo plates will return soon to complete the package. Only other thing I'm keen to add are the Damd carbon side/rear skirts.
Pure sex James!! Top job mate.
Red and grey/charcoal combo FTW!!!!
You made the right choice with the 18's. 19's may fill out the guards better, but you sacrifice handling, response and rwkw. I know from experience :huh: . For the past year I have been contemplating whether I should go 18's and sell the 19's :( .
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
