Hi Fellas,
I was wondering if anyone's had experience using oil filters other then Nissan genuine ones on their RB25DET NEO engines. Can filters used on Cefiro's, Primera's or other Nissan cars fit on the engine?
Edited by sarnil
https://www.sau.com.au/forums/topic/139364-rb25det-neo-oil-filters/
Just a note, after Nov 1998, R34's use a smaller filter to the standard z145a older R34's use. Both still fit though, but the smaller filter apparently has a different micron rating.
I have yet to find an aftermarket manufacturer locally for the later model R34's. So you're better off getting them from Nissan, they're cheap anyway.
Thanks Howie,
The last filter I used was the smaller version, but I had sent from Japan. It wasn't Nissan Genuine, but of the PITWORK brand (which I think is another Nissan brand).
Mine is a 1998 model, probably part of the earliest batches of R34 models.
Thanks Howie,
Send me your Vin number mate, i'll tell you what it should be.
Edit : Also if you use the larger filter obviously you'll need close to or more than 5L of motor oil.
Edited by Howie
All Skylines up to 11/98 use the Ryco oil filter Z145A or equivalent.
Skylines from 11/98 onwards use a Ryco Z442 or equivalent.
Hope this helps.
http://www.rycofilters.com.au/catalogue/ap...n/model/Skyline
Hi Howie,
The VIN number is RB25106146
Edit: the above is actually the engine number. The VIN # starts with ER34*****
Edited by sarnil
hi guys,
sorry to hijack your thread sarnil, but i've got a 1993 R33 GTST series 1 and when i went to nissan to purchase an oil filter he gave me the oil filter part number 15208-53J00 and he's very certain that it would fit on mine.. is he right ?
cheers
seconded. or a Cooper filter, they are good quality too.
confirmed. Tests have shown Ryco to be crap under the generic brands...and coopers performed really good. The OEM Nissan seems to be good also and plenty of good reviews detailing low pressure drop and good filtering. Considering I got some for $9.50 each you can't go too wrong.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
