Hey all,
Lately i've been pondering all my options regarding my car etc and im having trouble selling it.
This is my situation.
P Plates, restricted to a non turbo car.
Own a 95 R33 GTS4 Auto (non turbo)
Also, it has a 4 stud wheel pattern.
I really like the car I have, the body and interior is immaculate and is mechanically better than A1. As much as i'd love a turbo car this is what I have. All the NA cars are 4 stud so that was something I couldnt avoid. However I shoot myself in the foot about getting an auto :(
Anyway, I dont want to pour great deals of money into a car that I would just sell in 2 years anyway to get a turbo. Now I know in a non turbo and RB25DET conversion is possible with the front cut swap?? But what is the situation with the GTS4? I understand it has the GTR drive line, so im guessing only a RB26DETT is possible to fit, or is a regular RB25DET also possible to fit to the all wheel drive system on my car? Also, if I was going to to do an engine conversion, so getting a front cut? Would that come with the manual gearbox etc? As I wouldnt be making the same mistake twice haha
Also, has anyone done a 5 stud conversion on their skylines? What is involved, cost etc? I'd want to get the bigger turbo brakes and what not as well as a new set of wheels anyway..
Thank you very much in advance all who help, I know this was very long winded.
-Macca
Edited by macca_r33
https://www.sau.com.au/forums/topic/139386-skyline-help/
The "normal" RB25DET has a different sump pattern, so you can't swap your 4WD sump onto the RB25DET.
The Stagea has a AWD RB25DET, but the manuals are like chooks teeth (the vast majority are autos too). You might have to settle for a GT-R gearbox, unless you can find a manual one from the R32 GTS4.
Clearly, if you get a half-cut, then you get the good brakes as well.
https://www.sau.com.au/forums/topic/139386-skyline-help/#findComment-2597647
An RB25 will fit, you cant use the GTS-T gearbox though, remember Stageas come with an RB25 and awd. Cheers blind elk, didnt know the sump patterns are different!
You would be best off buying a manual Stagea front cut with gearbox, that might be harder to find but you will/should get the gearbox/pedals/brakes etc etc.
To be honest you might as well save your money now and buy a turbo car later on...
Edited by Atreyu
https://www.sau.com.au/forums/topic/139386-skyline-help/#findComment-2597655
Ok thanks, god damn ugly 4 stud wheels haha...
https://www.sau.com.au/forums/topic/139386-skyline-help/#findComment-2597731
  • 3 years later...
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
