First of all i would like to say a big hey to everyone out there. (as this is my first post :mad:) Love the site tho allways find usefull stuff on here and good advice.
I have a couple of questions about what i should do and have some ideas dont know if they will work or not thats why i came here :( lol
Question 1:
Can a GTS4 be converted to have a RB25DET or would it be pointless cos it would cost to much cos of the fuss with the AWD?
Question 2:
would it be better to just buy a GTST and not worry with the fuss?
Question 3:
how much would it cost to put the RB25DET in the GTS4?
Question 4:
would the rb25det in the gts4 have better peformance than a normal gtst?
thanks in advance :mellow:
Edited by raZ1911
https://www.sau.com.au/forums/topic/139404-awd-rb25det/
  • Replies 40
Which GTS4 (R32 or R33)?
R32 GTS4 only came with a RB20DET.
Stagea RB25DET is the only engine that bolts straight in (in RB25s at least - obviously RB26 is an option).
As to performance, I took my low-mod R32 GTS4 from 115 awkW up to 180 awkW (included aftermarket ECU). You be the judge if it's worthwhile.
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2599046
perhaps buy a GTS4 and also a Stagea frontcut?
use the engine to get you a AWD RB25det conversion, and I know plenty of Stag owners would be interested in the front bar, the bonnet, the side panels, etc. you'd make your money back easy IMO.
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2600168
i may be wrong coz dont know much about 33's but didnt the r33 gts4 have a 25det in it so wouldnt it be easier to buy a 33 gts4??? and as you stated you wanted an r33
ok my bad i figured the 33 was a 25det in the gts4 but its NA thought it would be the same as a 32
Edited by paulmac
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2600786
Question 4:
AWD added about 130kgs to the R32 GTS-T when they created the R32 GTS4. With that in mind, I would say the added weight of the AWD hardware means your car would probably actually be slower than the standard rear wheel drive car in most situations. You must also consider that when the GTS-T isn't just a GTS with a turbo engine - brakes, suspension, wheels, etc. are all upgraded to handle the extra power, and you should consider this when costing a turbo engine conversion for a non-turbo vehicle. Depending on the results you want, it would be far more cost effective to boost traction via. suspension and tyre mods rather than swapping to all wheel drive.
Just my 2c.
would a stagea front cut be hard to get?
If you can't find one in your area, companies like Prestige Motorsport will locate one in Japan to your designated specifications and import it for you.
Edited by Big Rizza
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601056
would that cost much?
Dunno how much for a Stagea, but I'd say they would be comparable to the equivalent Skyline prices. As a guide:
Nissan Skyline R33 Gts-t Series 1 2.5L turbo 1993 - 95 model (RB25DET) 5 speed manual with good condition engine and body panels
from about $3,800
Nissan Skyline R33 Gts-t Series 2 2.5L turbo 1996 - 98 model (RB25DET) 5 speed manual (hard to source)
from about $4,900
Nissan Skyline R34 GT-T 2.5L turbo 1998 to 2002 model (RB25DET NEO) 5 speed manual
from about $7,100
Front cuts are sourced from Japan as whole vehicles, tested as a running unit, then cut up and shipped as a front cut. Vehicles are chopped just behind the windscreen, and typically include the front seats, engine and wiring, transmission and tail shaft, suspension, wheels and fuel pump. If sourced to order then other small parts not usually taken from the vehicle can be included on request.
More prices at http://www.prestigemotorsport.com.au/modul...rticle.php?t=22
Edited by Big Rizza
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601313
is that the same with the R33?
from about $3,800
from about $4,900
from about $7,100
yeah ill email them and ask about the cost, is there any other places that do it also just so i can ask around
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601378
Yes.
Dunno if any of these guys will source half cuts from Japan to spec, but I'm sure they could point you in the right direction...
http://www.justjap.com/halfcuts.htm
http://www.adelaidejap.com.au/front%20cuts.htm
http://www.japimports.com.au/halfcuts.htm
http://www.japanesemotorsport.com.au/engines.htm
Plenty of others out there.
https://www.sau.com.au/forums/topic/139404-awd-rb25det/#findComment-2601799
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
