R32 Gts-t (sydney)
Now I've got 2 cars and a bike its time to sell one of the cars.
Selling because I don't drive it enough to justify having it.
I've got a personal loan and credit card bill that I want to pay out so I can start seriouly saving to buy a house/unit/whatever they'll let me get on my salary. I wish I could keep its a really fun car to drive and gets alot of positive attention. Never been pulled over in it either. My other car I get pulled over all the time (when its running )
Ive only had the car for about 6 months and I mainly used it for highway driving. Got over 500kms easy on a tank.
1993 R32 GTS-T
Could be Type M (how do you tell?)
White
4 piston front brakes
Rego till Aug 07
114,000kms
Timing belt replaced a 90.000 by prev owner.
3in dump pipe (spit wastegate pipe) and full 3in exh with brand new 3in cat
Blitz blow off valve
Pod filter
17in rims
Air con with climate control
Power windows/mirrors
Adjustable front castor rods
Recent wheel alignment
Always run on premium or better
Included is a SAFC II that I haven't gotten around to installing yet.
Chasing $12,000 plates are NOT included.
Body is in good condition but has a couple of little scratches.
Int in excellent cond (I love the seats)
I've taken the car to WSID once and it ran 14.1 @ 102mph. With that mph it will run a 13 if you're willing to take off hard (I wasn't).
Any questions post or pm me.
A few photos attached, if you want shots of anything in paricular let me know and ill attach them.
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
