i have a r32 gtr for sale, its got rego till july next year,
its a 90 model and has 98,000kms on the clock.
the interior is in good nick and so is the body, has nismo n1 kit but is missing the rear bit of the sideskirts, the jack points are all straight and there is no rust aniwhere, the front cv boost need replacing and so does the water pump which leaks abit of water from the pump seal, also the oil return line for the front turbo seaps a tiny bit of oil, otherwise its a good car
i have a new genuine waterpump and timing belt kit that comes with seals and the idlers and tensioner that will go with the car if sold,
the chassis is in perfect condition wiv no forlkift marks aniwhere like the bodgy ones u see everywhere, and the car is dead straight
its got second hand cusco coilovers which i put in and has a 4 puck nismo clutch which is about 1500kms old,
its also got upgraded turbos and apexi power intake kit,
the turbos are garrett 2860r - 5, they r running 14psi of boost and the car has run a best of 11.7 @116mph and does consistent 11.8 11.9 passes, i have the timeslip for all the passes run,
it still uses the standard computer and standard fuel system so it shows by the mph and the et that the motor is in good health, i did a comp test and all 6 came back at 150 dead even,
car has buddy club p1's aswel, i have described the problems and this is a no bullshit car, thats all thats wrong wiv it,
im in no rush 2 sell so ill want what the car owes me which is $$ 24 500 maby slightly negoiatable..
if any1 is keen please give me a buzz
denis
0404 490 095
NO TEST PIOLTS OR DREAMERS
no trades thanks
reason for selling, is upgrading to a 33 gtr wiv a big motor.
pics will be up 2morro sometime.
cheers
Color?
mate the colouyr of the car is gun-metal grey!
dennis its garth here mate!
i can vouch for this car.
anyone keen on this car will not be dissapointed!
absolute top notch car!
pristine condition.
and dennis mate im in the hunt for a stock 32 GTR. so let me knwo if you knwo of any. thanks mate!
BUYER OF THIS 32GTR will be amazed. and instantly fall in love with it! dennis is a great guy and no-bullshit bloke.
best of luck with sale mate!
cheers Garth....
Son of a bitch!
This is exactly the sort of temptation I don't need!
Mate someone HAS to realise soon that an R32 with solid compression and aftermarket turbos is worth more than $20k easily! I'd never touch an R32 with stock turbo's again, so if someone is after a GTR, this is it.
Best buy I have seen on here for months!
Shame market is dead, if you end up getting desperate enough for a trade, I have a 96 model S2 stock GTST, might be easier to sell... hopefully someone will realise the bargain before you get that desperate tho.
19g's is cheap :P This GTR looks the goods in terms of quality, alot of people buy the rubbish ones but no dash lifting, straight panels, clean paint, nice rims, good turbo set up and even compression, 19k is a good buy.
Good luck in selling your car champ. If you have a car lined up, it probably would be one of those EVO 9's in the dealership next to where you took them photos.
I wouldnt drop the price anymore to be honest, cause 19k it will sell if someone knows what they are looking at.
thanks dude, i was at mitsubishi lookin at a evo for my mate, not me dude,
im goin 33 gtr hopefully if some1 buys this 1
cheers
thats the bottom dollar aswell, i cant afford any lower and it owes me 2 much more than the asking price
Edited by den001
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
