I believe there were some they didn't come with hicas as there is a powersteer pump available without hicas.
Most likely the n/a base model.
I'm probably wrong though as I don't know for sure.. Just something I vaguely remember.
I found heaps of R33's that didn't have HICAS, & they were factory original.
When I bought mine it was the only one I'd found with the system on it & these were only just complied cars we're talking about here too. The setup is actually a bit different & lacks the adjustments for toe that the HICAS type rear end has.
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2707798
  • Replies 97
- re-instate abs control function. (doesent have abs.. IDIOT) supply report stating operation ok
Hmm, I thought this one interesting, but I suppose it part and parcel with inspector inconsistencies.
When my car went through, I had the ABS fault light ON (I've turned it off due to common problems with it) in orange on the dash and no comment was made about it. ABS shouldn't matter if you can pass the breaking test.
Best of luck
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2708498
Best of luck
i have passed the breaking test.
thanks helso for the offer, when i can find the hicas i may take you up on that. :D
dam, they system is setup to focus more on the technicality than the practicality!
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2709391
Yeah bud, if there's a lock bar in place, we could do a swap. The only problem I forsee is that it requires a wheel alignment to be done after the swap, so if you wanted the bar back, you'd have to get two alignments done. For a time frame, I'd go with Nozila's estimate, but, now that I've done one, I think I could shave a half an hour to an hour off of it
Edited by heslo
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2710729
thats true, once you 'crack' the bolts so to speak, its alot easier to unbolt and re-bolt. i didnt have that luxury as i stated, i was first time the bolts were unbolted. but since you have (i presume) a lock bar then your bolts would be easy as to undo. pain in the back side none the less. wheel alignment is highly advised.
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2710855
maybe it would be easier to just borrow one thats already off, wanna lend me yours nozila?
i have to replace my battery in my boot with a dry cell batters i have been quoted $480 for one.
wat the hell this is bullshit, F@#K this government. seriously!
Edited by DriftR_33
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2711010
Yeah, it's screwed up but what can we do? If you don't want to swap with mine and get a replacement that you can use, I'm still more than willing to lend a hand.
thanks mate for willing to help me... :)
my mate found me a r33 hicas today and have installed it. cost me nothing HAHA :D:)
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2722137
. We need cops that stop crime instead of discriminantely fleecing certain members of the public & making them out to be the crims instead.
true ^^
1 of the reasons why i sold my old 33gtr years ago...they pulled me over and gave me a fine for changing lane @ a roundabout (glenelg) near the revolving restaurant. Another time they pulled me over to search for my 2 bov, but being stupid noobs, they couldnt find them, bov are under the engine bay in GTRs.
just anything they could find, they'll make that extra effort to fine/defect u
while the real bad guys are still out there doing the real damage
so bl jase, just a bad day out @ kfc :D
Edited by andz69
https://www.sau.com.au/forums/topic/139443-defected/page/5/#findComment-2722158
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
