Hey there guys,
Just recently I upped my boost to 10psi and fited my fmic and the car doesn't feel as smooth as it does at stock/ebc off (7psi) and at 13psi its very stuttery/jerky and theres quite abit of mis-fire. I recently threw in some BKR6E plugs in and they are 0.8mm gap so I'm leaning to believe its a coilpack problem as I had to replace my 6th one before (it was dying out and making the car only run on 5 cylinders).
So I'm planning to pull them out tomorrow to alraldite or silicon or whatever them to see if I can fix the problem before deciding to fork out for some splitfires. But the problem is I've no idea where to actually alradite them so I've taken some pictures of the coil, could someone highlight where exactly I'm suppose to apply the stuff or post a picture of their own showing where?
And I've also read people have cleaned the connection/contact point inside but when I've removed the rubber gromet/boot all I found was a spring and a small black (carbon rod?) stick that was unreachable as it was pretty high up there. Is this what I'm suppose to clean? The spring? The rod? Both?
Thanks all, sorry for all the questions but answers will be hugely appreciated! :O
Cheers,
Andy
Edited by OnGsTa
Not the spring and not the rod. You want to insulate the boot around it, and keep the spark inside the boot cavity.
I've done heaps of CA coils, just silicone the boot (you should be able to remove this), and give the rod a bit of a clean up with some fine wire brushing.
Thanks Howie, so I just want to apply the stuff on the rubber boot that I'm holding in the 3rd picture?
So the actual module (heavy squarry metal black thing) gets left alone? Or do I apply a thin layer over that as well?
You could ongsta... it wouldn't hurt. Sometimes coils crack at the actual module also due to them being dried out, so it's not a bad idea to silicone that also.
Before you start, get some electrical contact cleaner and spray inside where the spring and rod is. Clean up any carbon deposits on the rod end with a wire brush or very very fine sandpaper, and silicone the boot.
Just out of curiousity do you have much carbon build up on your rod ends?
Howie: the question is how much of the module do I actually cover up?
Bl4cK32: thanks for the advice will look into it.
Now heres a question: figured I'd ask here. If my coilpacks were the root of this problem, would I feel mis-firing/stuttering at lower boost levels? Or only when boost is fired up? Trying to figure out if its R&R or the coilpacks/spark.
I'd go probably all bar the connector snorkel. It won't make a difference to the running of the coil.
You'd only find that coils will misfire at lower boost if they're faulty. By upping the boost you're asking coils to supply you with more spark than they're capable of, but the coil itself is probably fine, it's just being asked to work outside of it's parameters.
If your coil pack was really really rooted, you can see the sparks when you open the ornament cover on idle!
use silicon 101, thats what i think its called. I use it on my coilpacks. I applied it to the entire coilpack except the bit in which the rubber boot covers. works a treat although im still having some minor drama's, dont know if its coilpack related.
Would it be missing at low boost at light throttle or heavy acceleration only Howie?
If they're faulty, they'd misfire anywhere between idle and part-open throttle. If you were in Adelaide i'd lend you my splitfires to test them with.
Edited by Howie
My coilpacks are playing up atm. It ONLY misfires on WOT @ 16psi.
I can drive around like normal off boost, or part throttle / boost (0.5bar) and the car is fine.
Its when i push the coil packs is when the spark jumps out.
definitly Waz.
Considering the short term fix, but seeing as the splifires are around $520 these days im just gunna save and drop em in.
I was told by an auto elec. that there would be breakages in the windings inside the coils, and botching them isnt the best, as once sparks have jumped they follow the track left constantly causing misfires and leakage down the future...
I think it’s odd that no-one has picked up that this is an R34 gtt.
10 psi on an R34 gtt with no aftermarket management has it in R&R mode.
How could you expect anything but worse at 13psi?
There is no harm in doing your coil packs, but don’t expect them to fix this issue you have.
You need management.
Never too young for coil pack issues. Sometimes coil packs dry out for a number of reasons, environmental, engine overheating etc.
I've seen coils go at 60,000kms, that's not uncommon depending on what series coils you've got.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
