Don't get them hiflowed. it ruins the spray pattern and costs nearly as much as getting a good set.
I look at it this way, Injectors are a CRITICAL part of your enging and if they dont work correctly it goes BANG seriously just get good ones to start with. $700 beats a dead engine :laugh: and relative to other mods they are quite cheap.
I look at it this way, Injectors are a CRITICAL part of your enging and if they dont work correctly it goes BANG seriously just get good ones to start with. $700 beats a dead engine and relative to other mods they are quite cheap.
I disagree, a few places actually highflow injectors correctly and pay attention to multi-port spray patterns, AVO, APS, deatschwerks etc. They work out to be a good option for people with R34's that can't get access to a range of injector sizes. The below injectors suit V35, 350Z and R34 RB25's
http://www.deatschwerks.com/nissan63.htm
what power levels are you chasing?? Stock shoud be fine for around 250 with pump and reg.
I'm after around 240kW at approx 18lbs with fuel pump, avcr, pfc, z32 afm, slide hiflow, fmic, 3" exhaust, filter and possibly cam gears and cams. So besides an fpr being dodgy way of fixing fuel probs the injectors are going to run out flow anyway.
Thanks, thats exactly what I was looking for. Anyone else wanna add some more sites with hi-flow injector prices and info?
240 on stock should be fine after changing just the pump and reg, check A/F and adjust the reg to fix (and of course your tune timing ect..), I am running 242 with stock pump and reg and stock injectors, I am changing reg and pump this weekend which should fix my 13 to 1 a/f bring it back to 12 to 1.
But if you want to be absoultly safe change them.
Edited by race_snooze
so you have 240rwkw with stock injectors just a adjustable fuel regulator and a bigger fuel pump? im also wanting to know what is the best road to take towards injectors? ive got cooler/exhaust/sliding hiflow/splitfires..soon to bolt in z32 afm and powerfc then get a tune on 15psi...my mechanic here can hiflow my injectors for $150..i dunno what to do?
yes that is correct, i am fitting a malpassi rising rate and a walbro this weekend. Why do you guys think you need to change your AFM for or your injectors.... tune it see what it needs instead of buying things you may not need. But like i said if you really want to play it safe get them first before you do lots of tuning then you dont have to constantly keep going back to the dyno if things are not right the first time.
are the prices US or AUS??? they look like they are from the states????
After having injectors hi-flowed by AVO I had my car tuned and have been happy for 2 years now.HOWEVER,I recently did some work to the car and needed to get it retuned so decided to see the Hitman in Penrith.I was amazed when he changed the flow on each injector and I could hear the difference on two of them.They weren`t pulsing correctly.He claims,and I agree that the spray patterns just aren`t right.To be honest,I never felt totally at peace as they were visually different on each hole.Thats four holes per injector by 6 injectors.
So now I`m waiting for my Nengun Nizmo injectors to arrive.I have the feeling I`ll be able to add some more timing due to better spray patterns.Fuel consumpsion will be better to.Thats the theory anyway.By the way,did anybody notice the Deuchewerks RB25 370cc injectors and how you can`t mix them with standard 370cc injectors.Does that tell you something? Obviously the spray patterns would be different and therefore if mixed different cylinders would run rich or lean.
I thought you meant 250hp in an earlier post. 240kW with stock pump/injects its gotta be leaning out like a b1tch, do you run a PFC?
Edited by BAMR33
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
