After having injectors hi-flowed by AVO I had my car tuned and have been happy for 2 years now.HOWEVER,I recently did some work to the car and needed to get it retuned so decided to see the Hitman in Penrith.I was amazed when he changed the flow on each injector and I could hear the difference on two of them.They weren`t pulsing correctly.He claims,and I agree that the spray patterns just aren`t right.To be honest,I never felt totally at peace as they were visually different on each hole.Thats four holes per injector by 6 injectors.
So now I`m waiting for my Nengun Nizmo injectors to arrive.I have the feeling I`ll be able to add some more timing due to better spray patterns.Fuel consumpsion will be better to.Thats the theory anyway.By the way,did anybody notice the Deuchewerks RB25 370cc injectors and how you can`t mix them with standard 370cc injectors.Does that tell you something? Obviously the spray patterns would be different and therefore if mixed different cylinders would run rich or lean.
That would only be common sense seeing as they would have flow tested and matched the set, throwing them in with factory ones would defeat the purpose of going to the trouble.
I thought you meant 250hp in an earlier post. 240kW with stock pump/injects its gotta be leaning out like a b1tch, do you run a PFC?
13 to 1 which is now fixed just need to dyno check that. Running a Nerve ecu Remap check the RB25 turbo upgrade section.
For less than the price of the "hiflowed" 440cc injectors from deatschwerks.com, I got a set of 6 x S15 480cc injectors for my R33. Just another option for you if you don't want to go the hi-flow squirts route...
I got 4 injectors from a guy on the Nissan Silvia forums. The other 2 injectors I got from Ebay (sent from USA). Total cost - $405 (before cleaning and flowtesting). The Ebay guy sells them brand new for ~AUD$100ea or 2nd hand for ~AUD$75ea
The S15 (Jap Spec only - I think Aus spec S15s have 370cc) injectors are direct drop in for the RB's. No collars or mods required.
Yeah, I know s15 injects would be a good option as per my first post in this thread. Finding 6 all in good condtion is a bit of problem though. Anyone got 6 or 4 or 2 they want to sell me?
Which ones from other cars are compatible?
I'm sure I've seen previous threads with mentions of RX7 ones. Also saw en ebay add for WRX ones and he 'thinks' they may be SR20 compatible which should mean R33 .. right ????
Any others???
Yeah the ones I posted are for R34's where getting injectors is a complete bitch.
Any others???
It depends which sr it is. I've never heard of wrx injectors into an r33 can anyone verify if this is possible?
yep i have heard this aswell, they do fit in.
Early WRX injectors are the same as JZ injectors (and SARD), they need an adaptor collar to fit RB25's.
Late WRX injectors look like RB25 Neo injectors but I haven't compared them directly.
:P cheers :(
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
